Sorta odd 1500 question...
frankenstang57
I'll start of by saying I'm a Triumph guy. I know a bit about Spitfires and Heralds. So when a co worker bought a '79 Midget and had some emissions control questions, I figured I'd help out. Anyway, the car is missing the air rail, smog pump and cat. After looking at it closer, there are no provisions in the head for the air rail. The car does have an EGR valve and 2 sets of mounts for throttle cables(?). From what I've learned so far is the block is a Federal Midget 1500 (FP6339UE) the head is from a 77? (TKC3239) and the vin # is GAN6UL213757G. The tag in the jamb says June 1978. I'm wondering if someone swapped out the head when they de-smogged it. It does have a double pulley on the crank. Any advice is appreciated. Thanx!
G
Well, I'm sorta an odd 1500 owner so maybe I can help. Yep, sounds to me they swapped the head (at least) if there aren't any plugged ports. IIRC I have a 3239 head here that came off of a '77 that doesn't have ports for the rail. My '79 has (IIRC) a 1409 or 1410 but I could be wrong. Find me a 2748 and I might just swap my smog head for it. I should still have the rail, pump and mount too.
frankenstang57
frankenstang57
Want to sell 'em? I have a spare 1500 head.
Scott_Hower
If you don't strike a deal with kellysguy...
I have a TKC1410 head if you are interested. It's low compression (7.5:1) with smog ports and hardened valve seats (CA smog spec). Recently removed from a running car. Includes valves, but no valvetrain.
The TKC1409 casting is also a low compression smog head (49 state/Federal spec).
NutmegCT Tom's new SLBC [Sorta Little British Car] ! Other British Cars 46
anarchy99 New Guy with a sprite... Sorta Spridgets 172
NutmegCT 1940 LaSalle [sorta ...] Other Cars 1
drooartz sorta kind ish maybe looking for a RHD Bugeye Spridgets 8
HealeyPassion Works rally tribute car... sorta done Austin Healey 29
PAUL161 It Sorta Followed Me Home? MG 29
drooartz It's alive [sorta]! British Motorbikes 4
E 2 Complete 948's & 3 Smoothies - Sorta Free Spridgets 15
goloch Back on the Road, Sorta MG 2
G General MG odd but true! MG 8
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
K TR2/3/3A An odd thought.....vinyl wrap a TR3? Triumph 8
K TR2/3/3A An odd brake question? Triumph 2
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
S Engine or Tachometer Odd Problem Austin Healey 7
PAUL161 T-Series Odd spark plug encounter! MG 10
Y MGB More things that seem odd.... MG 2
Y MGB An odd (and probable long-shot) request... MG 5
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A T-Series Arkansas MG Odd Lifter Wear MG 12
sparkydave Odd discovery, but still ran OK Spridgets 1
Rut TR6 Odd wheel Triumph 4
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
CJD TR2/3/3A Odd Commission number Triumph 16
steveg Odd problem but it got me home! Austin Healey 9
H TR2/3/3A Odd Speedometer Behavior Triumph 3
J TR4/4A Odd Commission Number Triumph 16
D odd photo Jaguar 6
K TR2/3/3A An odd 56TR3 Commision Number? Triumph 8
R Odd Wiring Failures Austin Healey 14
MisterB MGB New Guy- Looking at Early MGB-Odd one MG 5
AN5Sprite Source For Odd BSW Tap Needed Restoration & Tools 9
R Odd Bonnet question Spridgets 2
K TR2/3/3A Odd looking modified TR3 on Craigslist...saint luis obismo Triumph 24
DrEntropy This tops my "odd cars spotted" personal best Spotted 1
K TR2/3/3A Odd Clutch Failure...Clutch crosshaft bushing goes for a walk! Triumph 6
Flash_Harry MGB '71?? MGB on eBay - a bit odd?? MG 10
J TR4/4A Odd TR4 transmission question Triumph 10
J TR2/3/3A Need an odd part for a TR3 Triumph 4
M TR2/3/3A Tring to find odd TR3 parts again Triumph 24
T photo - odd request Triumph 5
TRclassic3 TR2/3/3A Odd TR3A suspension issue Triumph 11
D Odd pair today Spotted 17
A Ignition rotor recommendations - odd failure Austin Healey 11
texas_bugeye Odd rear suspension Spridgets 8
JPSmit Odd week for odd cars Other Cars 34
BoneIdle Odd squealing in 4th gear MG 2
Sherlock A rather odd truck/motorhome Other Cars 0
