MGB Noisy Rear Axle / Differential
prutland
I have a 1967 MGB Mk I Roadster which I used for a recent track day. The car has a banjo rear axle and I am trying to track down a problem that has arisen with it.
Driving home after the event I noticed that the rear axle had become suddenly noisy, with a pronounced "howl" that increased in pitch with speed. I do not believe that it is gearbox or prop shaft related.
I understand that there are a number of potential causes for a noisy rear axle, but I am having trouble identifying which it may be, and am therefore seeking suggestions as to how to trouble shooting the cause:
  • Thrust washers were replaced about 10,000 mile ago, but my understanding is that these are more likely to result in a differential "clunk" than whine
  • Rear hub bearings?
  • Differential outer or pinion bearing?
  • Differential bearing
  • Worn / damaged crown wheel or pinion
Any suggestions for tracking this down would be much appreciated.
Platinum
A "howl" without accompanying clicking or rattle usually indicates pinion/crown wheel misalignment. But a bearing can also be the culprit. Only sure way to know is a tear-down and inspection.
G Noisy Rear Hubs Austin Healey 6
Fanch00 Noisy Side Screens Austin Healey 13
T TR2/3/3A Noisy tachometer Triumph 9
4tecdog Noisy fuel pump Spridgets 6
JFS TR2/3/3A Noisy Lifter Triumph 14
vickxxx TR2/3/3A new water pump noisy after 6 months Triumph 5
Bugeyze Noisy spin on oil filter Austin Healey 9
M TR2/3/3A TR3A noisy heater Triumph 6
Boink It's probably noisy on the street... Rover / Land Rover 0
H Noisy diff in BJ7 Austin Healey 2
8 Noisy differential and fuel additive questions Triumph 9
Darrell_Walker Noisy A/C Triumph 27
JFS Noisy Lifter Triumph 3
V TR2/3/3A Noisy TR3a Engine Triumph 35
bighealeysource Noisy solid state fuel pump Austin Healey 15
T Noisy valves a problem? Triumph 18
KVH TR4/4A TR4A Suddenly Noisy Suspension Triumph 5
R noisy fuel pump MG 6
T Datsun 210 - noisy? Spridgets 8
RandallRK Head gasket / noisy engine Austin Healey 13
G Noisy valvetrain Triumph 22
delisaj TR6 tr-6 noisy clutch? Triumph 7
S BJ7 Noisy Muffler Austin Healey 0
Z Noisy valve train in rebuilt motor? Plus pics... Triumph 4
Woodie noisy shifter Spridgets 23
Brosky Noisy door checks - any fix known? Triumph 5
P Noisy Fuel Pump? Triumph 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
