MGB MGB rear break rebuild
Carlbanan56
Carlbanan56
Member
I am currently overlooking my rear brakes, and both of the cylinders are leaking. So I will have to buy new ones. My question is if I should order anything else for the rear brakes while I am at it? It is an MGB 1975 that has not run in 25 years. I was thinking of getting a new shoe set and springs but I still want to be cost-effective. Is skipping out on the springs a bad idea?
Young and inexperienced
Mickey Richaud
In order to replace the wheel cylinders, you'll have to remove the brake shoes, which involves removing the springs as well. If I were doing the job, I'd replace everything. Spring kits aren't that expensive ($25 or $30 for both sides), and there's always the chance that one or more might be weak or broken or lost in the process.
Mickey Richaud
Okay thank you, I will buy a spring kit and the cylinders. Is it necessary to buy new shoes and new drums?
Shoes, yes, I would; drums, maybe. But depending on their condition, you can probably get by with just cleaning them up well and lightly sanding the inner surface. If you look inside the drum, you should find the maximum allowed inside diameter; if over that, then you'll need new drums. Other than that, you may be lucky and only have to have them checked and perhaps turned at a machine shop.
Mickey Richaud
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
H Wanted 1970 MGB rear bumper irons MG Classifieds 0
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Mickey Richaud MGB Rear Bump Stop - MGB MG 2
PAUL161 MGB Wanted-Early MGB Banjo Rear MG 15
N MGB-GT 1971 MGB Rear Shock mounting bolt length MG 0
Lynn Kirkpatrick T-Series '68 MGB GT Rear Hatch MG 0
S MGB-GT Using MGB GT rear springs in an MGB? MG 4
M MGB MGB rear springs VB Thailand made MG 3
glemon MGB MGB Rear Tranny Seal MG 7
B MGB Wanted, Rubber bumper MGB rear springs MG 0
T MGA MGA vs MGB rear axles and differentials MG 31
R MGB MGB Tube Type rear differential MG 0
M MGB MGB Banjo Rear Hub re and re wire wheels MG 0
RickB MGB NOS left rear bumper for 70 MGB - GONE for $62 MG 0
V MGB MGB -softening rear suspension MG 8
davester MGB MGB rear tube shocks...which ones? MG 18
K MGB First stupid question. rear deck hardware 71 mgb MG 17
M MGB MGB Rear Spring Lubrication ? MG 1
mgbmedic MGB rear tube shocks for MGB MG 20
PAUL161 MGB MGB Rear Disc Brake Conversions MG 14
S MGB 1975 MGB Overdrive rear seal MG 2
tony barnhill MGB MGB Axles & Hybrid Rear End MG 129
R6MGS MGB RB MGB rear lisence plate holder..... MG 9
DrEntropy MGB The project: MGB trunk/rear. MG 20
C MGB MGB Rear Shocks MG 5
G MGB rear disc brakes for an MGB MG 5
B MGB MGB Rear springs from VB MG 4
K MGB 73 MGB rear axle seal MG 7
S MGB mgb roadster : sticking the hood to the rear moving bar of the cage MG 12
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
