MGB Advice for new MGB owner?
joelodom
Member
Hello! I just bought my Dad‘s 1970 MGB. He was the original owner and kept it pretty nice. It runs well and is well cared for overall, I want to take good care of it Other than reading through these threads, what do I need to think about? Are there customizations I should consider? How do I make sure I don’t make a mess of anything? I’ve never owned an old car before.
J
joelodom
Member
Thanks, Bob. Right now I'm in learning mode. Reading the manual, trying to understand what's going on in the machine to know what to keep an eye on. I just discovered that it's been operated with the overdrive lever on for an unknown amount of time, but maybe that's okay because the lever doesn't seem to do a thing.
NutmegCT
Congratulations on the great looking MG! As we heard back in the 1980s "Trust, but verify".
"the lever doesn't seem to do a thing"
hmmm - something wrong there. Could be the OD system died. Take it slow when you're investigating.
First advice I have: find and join a local MG or British car club. You'll get some hands-on experienced advice from folks who can come take a look at problems in person. One suggestion:
It's great that you're following your dad's tradition. Good to have you with us!
Tom M.
Little1
Make it a goal to learn how to do a basic tune up. New cars are maintenance free. Old cars, however, need regularly scheduled adjustments to valves, points, timing, brakes, and sometimes carburetors - in addition to the changing of fluids and filters you would expect.
When all cars were this way, you would find a mechanic on every corner capable of diagnosing, by ear, and repairing, often by adjustment. Now, cars are diagnosed by plugging in a reader to see what the onboard computer has recorded, and repairs are often accomplished by replacing sensors that feed that computer information so the computer in the car can make the adjustments. As result, today's technicians are trained differently and experienced in different arts.
In other words, you are literally the best mechanic for your car available today, because you care and you have the time to research something that the person in the shop does not. Armed with a good service manual, model specific internet forums, and a local club, you will be amazed at how good a mechanic you really are. This interaction with the vehicle, challenge and success, becomes as much of the reward of a relationship with a classic car as driving it.
Get a little notebook from the dollar store and a pencil and put it in the car. Record the dates and mileage and part numbers of your efforts. Over time, it will be invaluable for keeping track of not only what is needed, but also provide clues for investigating solutions for things. I'm not quite as old as that makes me sound, I use screens for everything else, but the old ways for the old cars do work and have a mellow vibe at the same time.
Enjoy the journey.
Bob Branson
Member
You are blessed with a documented original chrome-bumper B, (even if it IS a Leyland and not BMC.). Don't change ANYTHING, because it will make it less collectible. Beginning with '68s, there were sometimes smog pump problems that gave everyone fits at first. All good advice above, but the best was to join an MG club. Car guys are always happy to help.
YakkoWarner
All the cars had the overdrive lever - it doesn't mean you necessarily have an overdrive transmission (they just didn't want to make 2 versions of the combined control lever). You would have to look at the actual transmission from below to see if it has an overdrive unit on the back end.
J
joelodom
Member
Thanks! I bet my Dad purchased it without overdrive, if that was an option in 1970. I'll take a peek and see if I can tell. So much to learn...
Platinum
Just curious, what is the "lever" you refer to? And the best manual for the car will be the Bentley Press "Official MGB" publication.
Looks like you've a gem there, BTW.
J
joelodom
Member
Thanks! The overdrive switch is on a lever on the right side of the steering column, but it's inoperative or the car didn't come with OD. I checked on the Bentley Press book and it looks like Official MGB is only available for 1975+, as far as I can tell. I love driving it. I've gotten used to its idiosyncrasies. I'm going to post a question or two in a new topical thread after I search the forums to see if it's been asked before.
Platinum
My guess is you do have an overdrive fitted. It should only work (and only be switched on) in third and/or fourth gear. I don't recall seeing the lever style OD switch mounted in the binnacle of non-OD 1970-'76 cars.
Check Ebay periodically for the Bentley manual appropriate to your year. They do come up. And a club member in your area may know of one available as well.
Platinum
You won't get dinged for asking something that may have been posted in the past, this place is built to be tolerant and informative. (y)
J
joelodom
Member
I found a copy of the 1962 - 1974 version. Thanks!
Joe Reed
I'm assuming the lever to which he refers is the windscreen wiper lever - which also functioned as the OD switch - changed with the OD switch was moved to the shift knob. I thought the same switch was used regardless of the transmission. Even that lever on my first MG ('72 Midget) flicked back and forth. I assumed they only used one switch to avoid stocking two different parts...
Platinum
P'rolly right, Joe.
J
joelodom
Member
I took it to a car show this morning and met a very knowledgeable mechanic. He looked at the transmission and said it doesn't appear to have an overdrive. Thanks, everyone for the advice! I have a lot of fresh advice from this morning to digest.
S MGB-GT New MGB GT owner, looking for some general advice. MG 18
blacknite3 MGB New MGB owner seeking Heater advice MG 12
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
Parker MGB MGB Chrome trim strip installation... need advice! MG 10
slim1967 MGB-GT Advice on where to begin! 73 mgb gt MG 6
G MGB-GT advice on MGB GT evaluation MG 4
M MGB MGB door lock advice MG 2
R6MGS MGB MGB heater install....advice??? MG 7
T MGB Looking at a 74 1/2 MGB need advice MG 30
M MGB Modern stereo units for MGB's? Any advice? MG 19
A MGB Buying 1977 MGB Advice Needed MG 3
N MGB NEED YOUR ADVICE ON MY BRAND NEW [OLD] MGB MG 52
tr6web TR6 Need advice removing downpipe nuts Triumph 4
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
R Weber DGV Advice Requested… TVR 19
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
W Need advice on installing new side curtain glass Spridgets 1
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S TR2/3/3A Troubleshooting Advice Triumph 25
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
S Heater and fan control replacement - any advice? Austin Healey 9
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
AngliaGT Thoughts/advice on Miatas? Other Cars 22
B Austin America advice Other British Cars 2
N Electrical Troubleshooting Advice Needed Spridgets 6
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
steveg Advice wanted on HF impact wrench purchase Austin Healey 12
Bayless Need wheel bearing advice please Spridgets 4
W Advice please on 1930's? steering wheel and rack Other British Cars 3
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J advice on a 3 brush generator please C45N-3 Other British Cars 0
P Rechrome Advice Austin Healey 23
Bugeyze Engine mount advice please Austin Healey 9
