Advice wanted on HF impact wrench purchase
steveg
I finally have a compressor that will run an impact wrench. I'd like one that will remove the front crankshaft nut.
Am looking at the bewildering variety of air wrenches in the HF catalog and would like some experience-based guidance.
How many Ft Lbs do I need for the front nut? Was unable to find a torque value for it.
Healey Nut
Forget the air impact and just buy a 1/2” milwaukee battery impact instead .
These impact wrenches far outdo anything my air impact can .
Keoke
Well steveg
I might suggest that an electric powered Impact wrench is a better choice than an air powered one, whether it is rechargeable
or 120 / 240 volts AC IS INDIVIDUAL CHOICE .
BUT mop THEY ARE JUST SO MUCH MORE ADAPTABLE THAN THE AIR POWERED DEVICES.--just A THOUGHT
I am not at my shop and I am heading out of town, But I vaguely think it is 750 ft. / Lbs.
However. It will remove the crank nut in a split second.
... How many Ft Lbs do I need for the front nut? ...
All of them.
I got HF's 3/4" wrench, but couldn't find an impact socket in the right size so used a regular socket (carefully). The problem is getting at the nut with the cross bracket (not the right word, I know), even with the engine raised. IIRC, there are some 'compact' wrenches, but don't recall if I got one. Of course, if the engine's on the bench or stand, no problemo.
Jerry
Steve, I have the HF Earthquake 1" impact and it is not stronger than my battery powered Dewalt. In fact, I have not had it out for years now. Always using the battery version.
Jerry
HealeyRick
Thank you everyone for the advice. Will consider the electrics, too.
Some advertise "2 inch anvil" - what does that do?
Steve,
AFAIK, the "anvil" is the part of the wrench to which the socket attaches. You probably mean 1/2" anvil, otherwise you're shopping in the battleship tools department. I just bought this Rigid 18volt cordless unithttps://www.homedepot.com/p/RIDGID-...ch-Tool-Only-with-Belt-Clip-R86011B/301996008 It's very highly rated and it seems to have the juice on rusted lug nuts, anyway. Shop around and get it as part of a set with other tools, batteries and charger and you'll save a lot of money over just buying it individually with battery and charger.
glemon
Because of the cross member issue I tried breaker bars, then breaker bars with two foot pipe extensions with no luck. I ended up buying a large combination wrench, with the box end on the nut and my WW hammer whacking the other end it loosened with a few blows. The breaker bars, even the high quality ones, have some flex in them, the wider cross section of the big wrench, not so much, so force of the hammer blows times leverage go directly to the nut.
I would like to get a good electric wratchet and impact wrench, I have had air tools for years and just never got in the habit of using them much, my compressor is too noisy so I have to fire it up, with attendant noise, anytime I want to use them.
roscoe
Probably 2" long, not 2 inches wide.......The anvil is called that because that is what gets hit by the spinning hammer inside. When you see how these things work it's amazing they last through more than a few uses at all.
HealeyRick
nevets
I bought a plug-in Sears Craftsman impact wrench, which I mostly use on lug nuts when changing over to/from winter wheels on non-Healey vehicles. Works great. I was tempted to get a battery powered tool but wanted to avoid yet another battery to recharge and eventually replace. And since I only use it in the garage, there are outlets conveniently located.
dcarlg
Harbor Freight electric 1/2 inch impact worked fine to remove my crankshaft nut. About $40. Took several seconds. I bought the impact socket from ebay. 1 11/16". And a socket for the camshaft nut, 1 5/16".
Good luck.
Douglas
dklawson General Tech Brake Pad Brands and Materials - Advice Wanted Triumph 11
D 85 XJ6 Heater Core Replacement Advice Wanted Jaguar 19
GT6_Mark '84 Tasmin Advice Wanted TVR 5
Alan_Myers TR4/4A Exhaust advice wanted - TR4 Triumph 16
tr6web TR6 Need advice removing downpipe nuts Triumph 4
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J MGB Advice for new MGB owner? MG 16
R Weber DGV Advice Requested… TVR 19
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
W Need advice on installing new side curtain glass Spridgets 1
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S TR2/3/3A Troubleshooting Advice Triumph 25
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
S Heater and fan control replacement - any advice? Austin Healey 9
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
AngliaGT Thoughts/advice on Miatas? Other Cars 22
B Austin America advice Other British Cars 2
N Electrical Troubleshooting Advice Needed Spridgets 6
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
Bayless Need wheel bearing advice please Spridgets 4
W Advice please on 1930's? steering wheel and rack Other British Cars 3
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J advice on a 3 brush generator please C45N-3 Other British Cars 0
P Rechrome Advice Austin Healey 23
Bugeyze Engine mount advice please Austin Healey 9
S TR6 new TR6 owner looking for advice Triumph 9
R Factory Hardtop Restoration Advice Spridgets 2
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
Simmo TR6 CARPETS advice pleaese Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
M Tool Advice Sought Austin Healey 3
C Advice for installing a 3000 Grille??? Austin Healey 7
