Advice please on 1930's? steering wheel and rack
Wizwag
Hello
Ive come here in the hope that someone can identify what car this steering wheel, column and box is off. The box is marked 'Bishop Gear patent 223863'. I think that dates it to around the 1930's. Apparently it was used on Morris, MG? and another British car not sure which one. As you can probably tell Im not a car buff as such so I am struggling. I bought it as a bit of a punt. Ive done various google searches to try and identify the steering wheel but to no avail. The centre of the steering wheel is bakelite.
53088138_576054569561144_4186428090836058112_n.jpg53245209_576054549561146_7325343117358399488_n.jpg53164966_576054532894481_8013268750713225216_n.jpg
NutmegCT
Hi Wiz - welcome to BCF.
We have many folks with good memories, so you'll probably get some detailed replies sooner than you expect. Subscribe to this thread using Thread Tools (above your post) to get alerts.
Tom M.
Mickey Richaud
I'm afraid I can't help you with the steering wheel, but I have to comment on and ask about your forum name. Love it; are you perhaps related to Mr. Dickens? Sounds like a character name he'd have come up with!
Oh, and welcome to the forum!
:cheers:
Mickey
W
Wizwag
:cheers:
Mickey
Its just word I picked up from someone years ago and I found it amusing. He used it in the context of 'chocolate wizwag'. I'll let you use your imagination to work out what that is.
Bayless Need wheel bearing advice please Spridgets 4
F Water pump replacement on my BT7 advice needed please Austin Healey 18
J advice on a 3 brush generator please C45N-3 Other British Cars 0
Bugeyze Engine mount advice please Austin Healey 9
F Which spin-off oil filter adapter for my BT7? Advice please Austin Healey 7
matmire rocker arm stress cracks? advice please. Spridgets 2
S Tracing history of a UK BN1, advice please! Austin Healey 4
L Healey 3000 restoration help and advice please... Austin Healey 18
J TVR engine advice please TVR 7
catfood About to pull the engine, some advice please Austin Healey 4
D Car Buying Advice Needed Please :] Other Cars 2
KVH TR4/4A Engine Noise--Advice Please Triumph 39
P Beginning restoration, advice please Spridgets 28
H hood-tight fit-advice please Austin Healey 4
C Some carb advice please. Austin Healey 9
KVH Sheared Off Bolt [Tranny to Engine]-Advice Please Triumph 13
J Welding advice please Restoration & Tools 9
J Advice please on buying Jaguar E-type Jaguar 6
R Considering Purchase! Advice Please Triumph 23
I TR6 TR6 hard top advice please Triumph 3
T BJ7 -lost reverse, then 3rd/4th - advice please! Austin Healey 10
RickB Rattle can advice please Spridgets 76
rosalind electronic ignition conversion - advice please? British Motor Corp 3
MCNX_BFF Under bonnet ugliness-advice, please Triumph 13
C TR6 TR6 Advice please: weak spark? Triumph 7
M Brakes stuck , advice please Spridgets 9
T TR4/4A Test fitting TR4a rollbar - some advice please Triumph 1
RedTR3 Advice please on what this could be.. Triumph 4
B TR2/3/3A TR3A Radiator advice please... Triumph 13
tweety carb advice please Spridgets 4
A TR4/4A TR4A mixture problem - need advice please Triumph 41
timbn2 I need some sage advice from my Elders, please... Austin Healey 10
DonPete3 A bit of advice please. Spridgets 11
dklawson How to dispose of a car. Advice Please. Other Cars 56
bash Air compressor advice, please Restoration & Tools 18
78Z Considering a 65 Midget - advice please Spridgets 10
H 1956 Ford Zephyr mk2 - any advice please Other British Cars 1
H Recent BJ8 purchase- advice please Austin Healey 8
JM1NA TR2/3/3A Possible TR3 purchase, some advice, please.... Triumph 13
tr6web TR6 Need advice removing downpipe nuts Triumph 4
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J MGB Advice for new MGB owner? MG 16
R Weber DGV Advice Requested… TVR 19
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
W Need advice on installing new side curtain glass Spridgets 1
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
