TR2/3/3A Advice on how to get VIN number stamped into new plate
Joel Lester
Getting very close to finishing up my TR3 restoration and I got one of those new plates for the VIN under the hood. Does anyone have advice on where or how to get the my VIN number stamped into the new plate?
Thanks in advance!
Joel
Frank_D
I bought a set of lettered punches at Princess Auto for just this purpose. After careful alining in a bit of a jig, it worked well. To give the new plate some patina I threw it into a tin of old nuts and bolts and gave it a good shake. Worked out well.
Joel Lester
Joel Lester
Awesome! Princess Auto... I didn't think of them. I'll check it out.
Rod-H
Bronze
Please note, the originals are not exact, so don't get it too perfect
TFB
I purchased a full set of 3/16 letter/number stamps from amazon for less than$20.
Lots to choose from so you can get close to original fonts.
Tom
mctriumph
My advice is to save the original plate and by going inside the car and( using longer rivets), fix it to the backside
of the new one.
MD
RGK
Tom
Anyone know what the original fonts were?
Platinum
Not in the know, but are the originals stamped into or raised letters like on most cars.
They were stamped in Triumph and MG cars, hand etched in all the Lotus cars I've seen (or owned).
Haven't yet found a good set of stamps to mimic the original fonts. Close, but not "concourse correct".
tr6web TR6 Need advice removing downpipe nuts Triumph 4
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J MGB Advice for new MGB owner? MG 16
R Weber DGV Advice Requested… TVR 19
W Need advice on installing new side curtain glass Spridgets 1
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S TR2/3/3A Troubleshooting Advice Triumph 25
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
S Heater and fan control replacement - any advice? Austin Healey 9
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
AngliaGT Thoughts/advice on Miatas? Other Cars 22
B Austin America advice Other British Cars 2
N Electrical Troubleshooting Advice Needed Spridgets 6
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
steveg Advice wanted on HF impact wrench purchase Austin Healey 12
Bayless Need wheel bearing advice please Spridgets 4
W Advice please on 1930's? steering wheel and rack Other British Cars 3
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J advice on a 3 brush generator please C45N-3 Other British Cars 0
P Rechrome Advice Austin Healey 23
Bugeyze Engine mount advice please Austin Healey 9
S TR6 new TR6 owner looking for advice Triumph 9
R Factory Hardtop Restoration Advice Spridgets 2
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
Simmo TR6 CARPETS advice pleaese Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
M Tool Advice Sought Austin Healey 3
C Advice for installing a 3000 Grille??? Austin Healey 7
R Remove engine/transmission advice needed Austin Healey 4
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Windscreen removal advice Triumph 10
