Noisy Fuel Pump?
popularsurname
There is a loud noise coming from the boot of my 1971 TR6. I thought maybe the fuel pump was on its way out but having looked at it closely I now think its fine. However it pumps constantly (as soon as the ignition is on) and there is a mass of plumbing back there. It looks like there is a pressure switch which seems to be resonating. Can anyone answer these questions?
1. Should the fuel pump be on all the time?
2. Is there a pressure switch?
3. has anyone had this problem before?
Thanks
Richard
4tecdog Noisy fuel pump Spridgets 6
bighealeysource Noisy solid state fuel pump Austin Healey 15
R noisy fuel pump MG 6
8 Noisy differential and fuel additive questions Triumph 9
Fanch00 Noisy Side Screens Austin Healey 13
G Noisy Rear Hubs Austin Healey 6
T TR2/3/3A Noisy tachometer Triumph 9
P MGB Noisy Rear Axle / Differential MG 1
JFS TR2/3/3A Noisy Lifter Triumph 14
vickxxx TR2/3/3A new water pump noisy after 6 months Triumph 5
Bugeyze Noisy spin on oil filter Austin Healey 9
M TR2/3/3A TR3A noisy heater Triumph 6
Boink It's probably noisy on the street... Rover / Land Rover 0
H Noisy diff in BJ7 Austin Healey 2
Darrell_Walker Noisy A/C Triumph 27
JFS Noisy Lifter Triumph 3
V TR2/3/3A Noisy TR3a Engine Triumph 35
T Noisy valves a problem? Triumph 18
KVH TR4/4A TR4A Suddenly Noisy Suspension Triumph 5
T Datsun 210 - noisy? Spridgets 8
RandallRK Head gasket / noisy engine Austin Healey 13
G Noisy valvetrain Triumph 22
delisaj TR6 tr-6 noisy clutch? Triumph 7
S BJ7 Noisy Muffler Austin Healey 0
Z Noisy valve train in rebuilt motor? Plus pics... Triumph 4
Woodie noisy shifter Spridgets 23
Brosky Noisy door checks - any fix known? Triumph 5
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
