MGB ugh.....the fuel gauge went to *** again!
Guywith2Mgs
so I changed out the gas tank and float on my 1978 MGB. No issues. Fuel gauge worked great! fast forward about a year and a half and it is not working again. Now I do NOT drive the car much at all. its basically to go to car shows. The tank I think is full so suggestions to check this other than:
1. siphon out gas
2. remove the fuel float
3. replace.
I guess it could be the fuel gauge indicator on the dashboard or the float is crap, but it was new and i got it from Moss Motors..just a like replacement.
Grantura_MKI
Your tank should have a drain plug? Would pull the sender, if this is the only problem with the dials as they share current.
Brass floats are the best, but the senders are schyte in my opinion.
JPSmit
Not sure exactly how they are mounted in B's but it could also be the ground
BobHaskell
Assume the other gauges are working. If not, it could be the voltage stabilizer, or a fuse. There's a simple test to check the fuel gauge. Disconnect the lead at the sending unit. Turn the ignition on. The gauge should read empty. Ground the lead and the gauge should read full. Turn ignition off.
Leave the lead disconnected and use an ohm meter to measure the resistance of the sending unit. It should be around zero if the tank is full and about 100 - 200 ohms if empty.
PAUL161
I had the same problem and it was the voltage stabilizer. On the 72 it was positioned inside high on the driver's side firewall. PJ
G
Guywith2Mgs
I love these forums!! thank you!
NutmegCT TR2/3/3A My 1959 TR3a now for sale [ugh] Triumph 33
bugedd Just stumbled upon this, ugh Spridgets 11
Branson ugh.....the spridget salad bar Spridgets 7
mrsprite Ugh.....poor, poor Bugeye! Spridgets 6
V MGB Moss MGB gearbox gasket - ugh! MG 14
B rear wheel cylinder C clip install?? ugh Spridgets 24
RJS Questionable Mechanics - Ugh Triumph 17
T Ugh... Triumph 22
mikecyc72usa Ugh! Frustration!! Triumph 16
aeronca65t Ugh! Other British Cars 12
Rob_P T-Series Ugh, clutch fluid all gone... MG 12
F ugh!!!! these brakes Triumph 9
aeronca65t Ugh! Spridgets 13
Nunyas ugh... just when I least expected it... MG 17
J MG sold ! If this doesn't beat all! UGH! Guess who MG 9
Stewart UGH Rant warning MG 11
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
