Fuel Gauge
DavidThorn
The car is a late BJ8, suddenly the fuel gauge has deflected to full, and beyond.
I have taken the cover off the sender unit. All seems OK the float is moving properly the "probe" is about halfway along the coiled wire resistor which is correct as the tank is about half full. The sender unit has a good earth.
Have pulled the dial out of the dashboard, but seems connected properly and it has a good earth.
Every connection I check, apart from earth obviously, is giving a full 12-volt reading.
Any ideas?
David
mezy
If you look at the wiring diagram below. you should have a solid green wire comming from fuse 4 to the terminal B on the gauge.
Then a green / black off terminal T going to the sender unit.
If you disconnect the green / black wire from the gauge, the gauge should drop to empty.
If not there should be a black ground wire on the gauge for the light, disconnect it, if the gauge drops then it is earthing through the
case of the gauge and is Faulty.
If it does drop to empty, then the gauge is good.
Disconnect the other end of the green / black wire from the sender unit. the gauge should go to empty, if it does then there is a problem
with the sender unit.
If the gauge stays high then you have an issue with the green / black wire grounding somewhere.
Goldie
If memory serves me, check that the wire from the sending unit is not grounded. I think the it will show full if grounded at the sending unit ( essentially zero resistance). Maybe something has shorted the connection to the sending unit in the trunk.
DavidThorn
Thank you so much for your assistance.
I followed the guidance of Mezy and the diagram, everything checked out as ok , I reconnected it all and the gauge seems to be working normally.
Perhaps there was a fault or perhaps just a bad connection somewhere which when re connected was sorted.
Anyway a result !!
David
mezy
Anyway a result !!
David
I love it when a car fixes itself, do do do doo...... do do do doo.
The machines I look after at work, mostly made by a company from holland, MOBA, can break down. I can spend a couple of hours checking sensor signals are going back to the PLC, testing for wiring faults, bad windings in three phase motors, and air leaks on rams, and find nothing, only to have them start back up and work fine.
And that's another MOBA mystery.
G MGB ugh.....the fuel gauge went to *** again! MG 8
roscoe Fuel Gauge Austin Healey 0
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Fanch00 Inoperative Fuel Gauge Austin Healey 10
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
R TR2/3/3A Fuel Gauge Triumph 19
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
C MGA Fuel gauge question MG 8
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A Fuel gauge readings? Triumph 12
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
K TR2/3/3A Fuel Gauge again.... Triumph 11
N Fuel gauge problems? Spridgets 9
warwick-steve Fuel Gauge always shows 1/4 full Austin Healey 27
N Fuel gauge problem's? Spridgets 4
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
George Zeck Looking for a fuel gauge ...... Spridgets 2
S Fuel Gauge Question Austin Healey 8
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
warwick-steve Fuel Gauge always indicates 1/4 full. Austin Healey 13
J Fuel sender, fuel gauge 100 4 Austin Healey 6
George Zeck What fuel gauge SHOULD I have? Spridgets 3
sim 1958 fuel gauge sprite Spridgets 11
N Spitfire Fuel gauge Triumph 8
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
N Fuel gauge question?? Spridgets 3
B TR2/3/3A Fuel gauge problem Triumph 7
H TR2/3/3A Fuel sender or gauge? Triumph 8
F Running out of fuel - gauge problem? Austin Healey 5
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
K TR2/3/3A Fuel gauge and switching to Neg ground? Triumph 2
K TR2/3/3A Can a TR4A fuel gauge be used in a 3A? Triumph 8
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
Rut Bugeye fuel gauge Spridgets 14
Editor_Reid Fuel Gauge for 1967 Sprite Spridgets 4
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
