1958 fuel gauge sprite
sim
Been working on fuel tank and sorting out a problem with fuel gauge. I had the gas tank off and replaced the sending unit gasket which was leaking. I also cleaned the connection to the sending unit. After reinstalling I checked the gauge to see what it would read with an empty tank. It was just to the right of the empty mark. I then added some fuel and it read 1/4 tank. Added more fuel and it did not move . I then filled the tank and it still read 1/4 tank. So I have been driving it to see what it would read when the tank got close to empty. after a short trip today the gauge does not respond. I pulled the connector under the hood and the gauge did not go to full. I am guessing the gauge died. any other thoughts?
Thanks
Jim_Gruber
Your Float if Plastic has become a "Sunk". Replace the Float with a Metal One. Also take a look a thread posted by Leecreek on ahexp.com under thread posed about meeting Trevor Jessie by SaxMan. I now understand why my new tank only reads 3/4 full. Read the note and see if it applies to you. But betting you've got a "Sunk".
sim
sim
I will do that However float in metal and not sunk. This is still the original one that came with the car. I have had this car since 1973
Jim_Gruber
Jim Here is what my brother and I found after the run to Lake of the Ozarks. The gas cap was a fight to r+r. My brother installed a new gas tank in the late 80's Cap never fit easily after that. Well we measured down the fill up pipe at his house on the way back and I do not remember the numbers but the length of the fill up was just too short to get a hand hold on the cap. When I was getting ready to paint the Sprite in 2008 I removed the tank to cut and extend the Fill up tube. I cut it off about 1-1.5 inches above the tank to put on a hose. Looked and measured the stub left in the tank and it was over 2" long inside the tank. Since the fuel tank is not vented but the cap is I slotted the extension inside the tank just below the welded top with a cut off wheel on the Dremel. Now I am getting a fuller tank. Before the gas gauge started dropping rather quickly. Now moer 'back to normal'. My brother said they must have made the tank on a Friday or Monday. Just my experience here. YMMV He calculated by the numbers and said it gets a little more than a gallon and a quarter in the tank as the tank quits filling once the level gets to the fill tube.
dklawson
From post#1:
From post#3:
Can you see the float in the tank??? Float arms can also get "stuck" from deposits and rust. However, your post saying you removed wires and the gauge didn't change suggests this is not a sender problem.
When you pulled the wire off the gauge, you were removing the green/black wire from the gauge's "T" terminal weren't you?
The magnetic gauges have to have a very good ground connection. Make sure your fuel gauge has a good ground by running an additional wire if necessary. If that does not fix it, visit the MGA Guru website and read through the gauge system and how to calibrate it. If you like gauges this can be interesting reading and fun to try.
MGA Guru Fuel Gauge Link
smaceng
Double down on everything that Doug said......good luck....if it turns out that you need a new sending unit, see if you can find someone who can rebuild it. New units seem to have a short life. Scott in CA
sim
sim
no cannot see float but did check it when I had it out and it moved with out any problem.
The wire that I disconnected is under the hood on the right side. This should have made the gauge read full. I am going to test that connection with a test light to see if it has power. Next step is removing gauge.
thanks Rod
dklawson
I'm glad you found the fuse problem. So the next question is "why did it blow"?
F 1958 Frogeye with fuel problems Spridgets 9
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
P For Sale 1958 sunbeam rapier convertible and hardtop (coastside/pescadero) Other British Classifieds 0
S 1958 100/6 Bumper Brackets Color Austin Healey 2
jfarris Immaculate 1958 Bugeye Spotted 4
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
A 1958 Triumph 6T restored British Motorbikes 5
doc50 For Sale 1958 Metropolitan Other British Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
N Please help --- New owner of a 1958 Austin Healey Sprite Spridgets 4
S For Sale 1958 tr3a Triumph Classifieds 0
doc50 1958 Metropolitan Progress Other British Cars 4
doc50 1958 Nash metro door questions... Other British Cars 6
V TR4/4A Learned to drive in my father's 1958 TR3 58 years ago, never got over it Triumph 3
M TR2/3/3A 1958 TR3 Project Triumph 85
dougie 1958 100/6 "s" Austin Healey 6
M TR2/3/3A Where can I get British Racing Green, 1958 Triumph tr3a touch up paint in the USA? Triumph 3
2billydavies TR2/3/3A question about 1958 TR3a engine number, body number, etc Triumph 7
H 1958-1961 Austin Mini 850 speedometer housing pod British Motor Corp 3
maxwedge5281 1958 bn6 side curtains Austin Healey 26
F 1958 Meadows FriskySport Other British Cars 9
2billydavies TR2/3/3A dashboard/instrument panel on 1958 TR3a Triumph 4
HealeyRick Goldie at Earls Court 1958 Austin Healey 1
sim 1958 sprite lug bolts Spridgets 8
madhouse 1958 100-6 VIN check [BT7 vs BN4] Austin Healey 7
P Bugeye #6519. 1958 or '59 Spridgets 3
CZ_Dave 1958 Chevrolet Delray Car B Que Other Cars 2
mgbmedic TR2/3/3A My 1958 TR3 project Triumph 6
R TR2/3/3A Where is my 1958 TR-3A? Triumph 0
J My 1958 Bugeye is on EBay. Spridgets 4
bighealeysource looking for a Jensen batch number for my 1958 BN6 Austin Healey 8
dougie 1958 Sebring Sprite Austin Healey 0
J Anyone interested in very original 1958 Bugeye? Spridgets 1
S Correct Generator for Austin Healey 1006, 1958 Austin Healey 9
W I got the 1958 100-6 home Austin Healey 21
sim 1958 ignition light ? Spridgets 5
ronzet 1958 BN4 Horns Austin Healey 1
ronzet 1958 AH 100-6 Torque Sequence Austin Healey 1
M 1958 Bugeye Up-date Spridgets 15
JodyFKerr Craigslist: 1958 BN4 Austin Healey 0
B 1958 Alpine Cup - vintage racing video Spridgets 4
M Redoing dash question for 1958 Sprite Spridgets 37
B TR2/3/3A 1958 TR3A front body attachment help needed Triumph 7
ronzet 1958 100-6 Seats Austin Healey 25
Brooklands 1958 Peerless GT Triumph 2
ronzet New Seat Backs 1958 100-6 BN4 Austin Healey 8
