Redoing dash question for 1958 Sprite
M
Mike
I have googled and searched my Haynes book for the proper dash set up for controls. Can someone post a dash picture that show where the controls (key,choke, turn signal, lights,etc) are located or refer me to a past post?
Thanks,
Mike
scoutll
Re: Redoing dash question
Mike,
Here is the MK 1 dash, a lot like yours.
Turn signal switch top, wipers lower left, lights lower right,
Key middle.
knobs from left are starter, heater, washer, choke.
Someone with a sprite should chime in shortly if there is much difference.
M
Mike
Thanks Tony, it's a 1958 Bug Eye. Edit function can be a life saver.
Mike
jlaird
Try this.
spritenut
58 Sprite dash
Fuel on left, Speedo, Tach, oil/water
Cables, Choke next to tach, starter far right top heater left side next to washer
Switches, wiper left of ignition/light (center) heat (cable) to the right of Ig/lt
Signal switch center above ign/light
Signal light is center above steering wheel.
mxp01
You should get a Moss catalogue. They have very good illustrations in it.
MXP
jlaird
The far right gauge above is an optional clock.
texas_bugeye
59 sprite dash the choke and starter pulls not in the dash yet. other wise this is it. I think.
jlaird
Starter and choke seem to be backwars to me. All my Bugeyes have had the starter way right.
bugimike
I agree, Jack, that puts the starter cable right in line with the solenoid and the choke right behind the carbs!
texas_bugeye
Sorry about the no picyure thing. The yellow dot is about where the choke goes and the blue is about where the stater pull goes.Stater pull should come straight thru the bulk head
to the starter switch.
Sarastro
The pictures in the Moss catalog are copied from the original parts manuals, so they should be definitive.
I have a copy of the original owner's manual ("driver's handbook") but it shows only the right-hand drive version. The LHD version is essentially a flipped version of the RHD, except that the heater and wiper controls are in the same place, as are the choke and starter, which seems essential.
texas_bugeye
I dont think they moved the location of the choke and stater switch. The starter cable would not reach from any other location.
jlaird
It would be next to impossable to have the starter anywhere but right behind the starter switch. It just ain't made to work otherwise.
jvandyke
So, the starter pull switch on a BE is way over in front of the passenger, but on the MKI Midget it's next to the tach. I'm wondering because the PO ditched it for a push button and a solenoid and I kinda like the pull knob so thought I'd return to it (bought this recently ebay )
There's a mounting ear right in front of the heater box on the right edge that I assumed was where the original starter switch would be mounted, cable straight through firewall and would end up roughly where the BE has it, don't see how it could ever snake over to the tach side. Enlighten me. I'll go look for pictures. I remember seeing Tony's '63 has a nice pretty engine bay shot but can I find it back? noooooo
texas_bugeye
I should be around next weekend I could swing by and you can take a look. Your in north dallas? Maybe Mike (Texas sprite) could come too! need to get out for a drive.
maxwedge5281 redoing brake lines Austin Healey 3
mikeyr redoing the wood on coachbuilt body Restoration & Tools 13
10musketeer Redoing the Vinyl Seats Restoration & Tools 17
6 i need some help redoing my rear seat British Motor Corp 0
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
M Getting behind the dash on BJ8 Austin Healey 4
Rut TR4/4A Dash color Triumph 9
Rut TR4/4A TR4 wood dash Triumph 26
J Walnut veneer for the dash, Look what I found! Austin Healey 12
I TR6 Thickness of original TR6 dash Triumph 2
S TR2/3/3A Dash Pot Oil Triumph 14
TRMark T-Series Dash for Sports/Racer MG 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
TomMull replacing walnut veneeron the dash Lotus 17
K TR2/3/3A Dash Lights Triumph 3
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
