Center Dash Switch Plate Painting
timsgolf
Hello All,
I recently found and purchased a replacement center dash switch plate. The one on the car now has the Overdrive/Normal stamp. I wanted one with Aux. instead since my car doesn't have Overdrive. I found one and purchased it. The stamped/lettered portion is not painted. I would like to paint that stamped/lettered portion white - I think the originals were white. Can anyone suggest the proper way to to the painting?
I thought about a rub-on method of some kind where you would rub the paint on with a cloth or something, allowing it to settle into the stamped/lettered grooves, then cleaning off the excess. Would that work? Or is there a better way?
Also, what kind of paint should I use?
Thanks in advance,
Tim
Patrick67BJ8
Hello All,
Thanks in advance,
Tim
I need one. Where did you find yours?
I think you have 2 choices: 1) the 'rub-on/swipe-off' method or 2) if you have the hands and nerves of a brain surgeon--or a really good pinstriper--you can fill it with a fine tip brush. Either way, I suspect you'll have to wipe off any excess with a soft rag and solvent and hope you don't smear your work (or let it dry and scrape excess off with a razor blade). Hobby shop model enamel--Testors is the go-to--works well.
Are you sure it should be in white? I think white would be hard to see against chrome; the switch labeling usually seen on Healey knobs or plates is red on chrome, and white on black (Bakelite) knobs (like the choke).
timsgolf
timsgolf
Good suggestions Bob!
As far as the white is concerned, that is what the current switch plate is - except for the one word Overdrive, which is red. I could go with red easily though - the exterior is red. The upholstery is solid black, but at some point I want to go with red piping there.
Side note: I inadvertently wiped the dials of a Smiths speedometer's trip meter. I found a near-perfect match for the yellow from Testor's called 'Blue Angel Yellow,' which I thought was pretty cool (they also have 'Navy Blue').
BillyB62 TR2/3/3A Wood dash & center console examples Triumph 7
L Light for BJ8 Center Dash Panel Austin Healey 17
A TR-3A wooden center dash panel photo??? Triumph 3
Xte Original covering center dashboard and top dash ? Austin Healey 5
V TR6 TR6 Center Dash Support Triumph 16
apbos TR2/3/3A TR3a Center Dash Triumph 38
T TR4/4A Ideas on restoring the TR4/6 center dash supports Triumph 6
S removing center section from the dash on my BJ8? Austin Healey 2
B TR4/4A What is this Steering Wheel Center? Triumph 6
BoyRacer Moss Motors Center Consoles Austin Healey 0
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
jfarris TR2/3/3A Ground location for center panel lights 56 TR3 Triumph 5
WHT Center-Shift Bellhousing Austin Healey 10
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
M TR6 Center cap for wheels Triumph 2
D TR2/3/3A center panel indicator light color Triumph 10
R Turn Signal Knob goes off center Austin Healey 9
J Nut size for BJ8 center console trim piece Austin Healey 8
D 62 center shift gearbox Austin Healey 11
R Center Gearbox Input shaft bearing Austin Healey 9
D 1962 center shift gearbox cover Austin Healey 7
AUSMHLY Distributor cap center pin melted Austin Healey 5
Rut VTO center caps Spridgets 3
glemon TR5/TR250 Steering Self Center Triumph 4
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
KVH TR4/4A Center Console Recovering Triumph 10
Michael Oritt Center rod, bracket and mirror info needed Spridgets 8
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Triumph Herrld center bonnet moulding, [chrome strip] Triumph Classifieds 0
55modified Splined mag wheels? Who makes or machines them without center adapter? Austin Healey 5
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Joe Schlosser Transmission Tailshaft housing off center Spridgets 3
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
A turn signal knocked off center Austin Healey 14
charleyf TR2/3/3A Center main cap engine Triumph 4
Raven62 Superlite wheel center caps Spridgets 0
Lukens TR2/3/3A TR2-3-4 Center armrest Triumph 3
GTP1960 TR2/3/3A Arm rest center console? Triumph 14
D Re-fitting vinyl on center upper console bj8 Austin Healey 3
Bob_Spidell Center shift boot Austin Healey 13
K TR2/3/3A Distance from center wheel hub to center wheel hub? Triumph 6
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
Got_All_4 Wedge Can this center console be refurbished Triumph 10
M TR2/3/3A Finding top dead center Triumph 6
maxwedge5281 center shift transmission shifter Austin Healey 3
Boink Center justification on everything now... FORUM Navigation Questions 3
F Adivce on how to center jets of SU HD6 carbs Austin Healey 3
