For Sale Center wiring harness for a 1959 Sprite
Coastalman
This is the center wiring harness for a 1959 Sprite. I bought the whole harness when I was restoring my BE and found the under the dash wiring to be in very good shape. This is the Moss cloth bound harness with all the ends on it to just put right in. I can send pictures if you provide an email address. $80 plus shipping from NC.
timsgolf Center Dash Switch Plate Painting Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
BoyRacer Moss Motors Center Consoles Austin Healey 0
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
jfarris TR2/3/3A Ground location for center panel lights 56 TR3 Triumph 5
WHT Center-Shift Bellhousing Austin Healey 10
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
M TR6 Center cap for wheels Triumph 2
D TR2/3/3A center panel indicator light color Triumph 10
R Turn Signal Knob goes off center Austin Healey 9
J Nut size for BJ8 center console trim piece Austin Healey 8
D 62 center shift gearbox Austin Healey 11
R Center Gearbox Input shaft bearing Austin Healey 9
D 1962 center shift gearbox cover Austin Healey 7
AUSMHLY Distributor cap center pin melted Austin Healey 5
BillyB62 TR2/3/3A Wood dash & center console examples Triumph 7
Rut VTO center caps Spridgets 3
glemon TR5/TR250 Steering Self Center Triumph 4
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
KVH TR4/4A Center Console Recovering Triumph 10
Michael Oritt Center rod, bracket and mirror info needed Spridgets 8
L Light for BJ8 Center Dash Panel Austin Healey 17
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Triumph Herrld center bonnet moulding, [chrome strip] Triumph Classifieds 0
55modified Splined mag wheels? Who makes or machines them without center adapter? Austin Healey 5
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Joe Schlosser Transmission Tailshaft housing off center Spridgets 3
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
A turn signal knocked off center Austin Healey 14
charleyf TR2/3/3A Center main cap engine Triumph 4
Raven62 Superlite wheel center caps Spridgets 0
Lukens TR2/3/3A TR2-3-4 Center armrest Triumph 3
GTP1960 TR2/3/3A Arm rest center console? Triumph 14
D Re-fitting vinyl on center upper console bj8 Austin Healey 3
Bob_Spidell Center shift boot Austin Healey 13
K TR2/3/3A Distance from center wheel hub to center wheel hub? Triumph 6
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
Got_All_4 Wedge Can this center console be refurbished Triumph 10
M TR2/3/3A Finding top dead center Triumph 6
maxwedge5281 center shift transmission shifter Austin Healey 3
Boink Center justification on everything now... FORUM Navigation Questions 3
A TR-3A wooden center dash panel photo??? Triumph 3
F Adivce on how to center jets of SU HD6 carbs Austin Healey 3
B TR2/3/3A tr3b center exhaust hanger Triumph 3
P Turning to Top Dead Center Austin Healey 11
Boggsy64 MGB What is the purpose of the center assembly at tranny mount? MG 2
MikeAH100M Center Support for 100 Dashboard Austin Healey 8
Bruce Bowker BN2 center horn button assembly Austin Healey 21
