General TR How can I remove the finish on this center console for my 7
Got_All_4
Bought some spray dye for the bad spots on my dash and center console that match absolutely perfect and thought this was going to be an easy job. Taping off some areas to test spray the old finish came right off, even with painters tape. How do I remove this finish without destroying the piece it's self. Any ideas? I tried thinner and it didn't touch it.
TRTEL
I second GTP's recommendation for acetone, but certainly urge caution. If the old color lifted like a coating using the new dye, check to see if the can provides the solvent base it uses. Then carefully check to see if the originally grain still exists below the bubbled up old finish. I haven't a clue as to what type of plastic was employed on 7s and 8s. And can only guess molded polyurethane foams. If the grain remains give it a thorough chance to air dry out before a final spray. And test small hidden areas with saturated cotton swabs. Other solvents you might try: ethanol, methanol, MEK, petroleum ethers (starting fluids but without lubricant). I would avoid using removers with methylene chloride. Good luck.
Got_All_4
Got_All_4
I wasn't that clear. It's the original OEM finish that is chipping off ether using a finger nail or that tape I spoke of earlier. The new spray die has not lifted anything. I just tried acetone, M.E.K. lacquer again and none of them budged it. The only thing that worked was paint remover but it really softened the plastic.. Also it seems like only the sun exposed areas are effected. Sections that are under the dash that are sun protected seems ok. I even tried a stainless wire brush to scratch off the finish and it didn't budge.
Darrell_Walker
I've had pretty good results with the citrus-based paint removers. It comes in a plastic container, so it might be safe for the plastic.
TRTEL
I've never tried the citrus based remover and that's certainly worth a shot. The remover you did try and softened the plastic probably has methylene chlorides in it and that stuff will just about soften anything. But having said that this might be worth doing a bit of experimentation. Try a few different volumetric mixes of lacquer thinner and that stripper you have. Say about 60% thinner to 40% stripper ( they should be mutual solvents, that is one dissolves in other). If that still softens the plastic beneath try an 80-20 mix. And by all means, safety first, out in the open air, all this stuff is bad news for the liver.
Got_All_4
Got_All_4
Thanks for the tips. I think it will work. I forgot I have a citrus based graffiti remover although it took about 5 coats most of the finish was gone. However it is now completely stripped. On of my customers has a very large bead blast cabinet that they use on bumper covers and other parts that are brittle. Does a great job and what I liked is it got into all the little nooks and crannies. I'll have to use the citrus base stuff for the rest of the dash that is still in the car.
I'll degrease it spray on a plastic adhesion aid then the color. I'll post how it turned out. But don't hesitate for other suggestions.
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
CARSINC How to remove factory contact cement? Spridgets 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
drooartz Hose from water pump to head, remove water pump? Spridgets 12
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
tahoe healey Nano Magic scratch remove Austin Healey 2
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
Basil 7 Ways to remove stripped screws Restoration & Tools 2
C How to remove entire dash panel on BN6? Austin Healey 4
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
C MGB How do you remove "speed nuts"? MG 9
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
R Remove engine/transmission advice needed Austin Healey 4
abarth69 Should I remove this section Spridgets 8
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
D TR2/3/3A wooodruff keys... how to remove Triumph 25
B remove BJ8 dash ? Austin Healey 1
Steve1970 TR6 Can I remove the shim on the rear gearbox mount [J-type OD] Triumph 11
4tecdog Access to remove Ariel Austin Healey 15
L Best Polish to remove surface scratches Austin Healey 12
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
C TR4/4A Best way to remove transmission fill port? Triumph 8
P How to remove the lever control? Austin Healey 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
D BJ 8 How to remove chrome trim strip from door tops Austin Healey 7
S TR2/3/3A remove protective covering off floor pans Triumph 6
bighealeysource Best way to remove dried polishing compound Austin Healey 10
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
NutmegCT How to remove old weather stripping Restoration & Tools 8
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
B Remove Crank Nut Austin Healey 55
R Can't remove rear flexible brake hose Spridgets 5
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
S TR2/3/3A remove a clutch fork Triumph 1
maxwedge5281 remove 100-6 grill emblem Austin Healey 1
J TR2/3/3A Remove old dash vinyl. Triumph 2
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
Boggsy64 MGB Advice - Remove the seats MG 8
C How to remove temp sensor at block? Austin Healey 16
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
Lukens TR2/3/3A Before I remove my steering box... Triumph 10
toysrrus TR2/3/3A What tool to remove Dust Cap? Triumph 12
