TR6 TR6 Windscreen remove and now windows dont fit
hondo402000
when I repainted my TR6, I took the windscreen off to paint it too. When I reinstalled it I didnt roll the windows up to see if they fit( my bad), as I usually only drive in nice weather and never roll the windows up, now when I roll the drivers side and passenger windows up they don't fit, Gap at the bottom and at the top they hit the windscreen frame, Where is the adjustment made? I am putting new passenger side and driver side glass in and there appears to be no adjustment in the tracks, so I assume the adjustment is in the frame, I also had a new top installed years ago too and afraid if I can get the windows to fit correctly by adjusting the windscreen frame, the top will not fit any more. Thoughts?
charleyf
The adjustment on your situation lies with the windshield. On each side of your windshield the post that goes down into the body needs to be loosened and the windshield moved into a position that accommodates the windows in the up position. There is the nut on the bottom of the "post" as well as the bolts that hold that plate/bracket the post fits into. You may well have to loosen the bolts that hold the windshield in place on the dash.
You are not the first to make this mistake.
This is not an easy place to get into on a TR6.
As to the fit of the top I say that you need to start somewhere and getting your windows to close is the logical first step.
By the way the TR4 and TR6 use the same windshield as do some of the Spitfires.
hondo402000
hondo402000
thanks I kind of figured that was how to adjust the Windscreen frame, so at some point I will bit the bullet and get it worked out. I need a new Windscreen gasket anyway, when I replace it I can work on the fit too
charleyf
I have found that replacing the windshield gasket is easiest done while the windshield is firmly planted in the car. That is unless you have some other way to firmly hold it in place elsewhere.
P For Sale tr6 windscreen Triumph Classifieds 0
I TR6 TR6 windscreen rubber seal help Triumph 2
TR6oldtimer TR6 TR6 windscreen and rear flat black Triumph 4
tr6nitjulius TR6 '72 TR6 Windscreen Washer Switch Triumph 0
R TR6 '71 TR6 Windscreen Vin Tag Rivets Triumph 1
R TR6 '71 TR6 Windscreen Restoration Triumph 1
I TR6 Windscreen adjustment help for TR6 Triumph 8
2wrench TR6 Need help removing glass from '74 TR6 windscreen. Triumph 13
2wrench TR6 Need help on '74 TR6 windscreen frame removal Triumph 6
TR6oldtimer TR6 TR6 Windscreen washer reservoir location Triumph 2
ez_pa_6 TR6 TR6 windscreen assembly removal Triumph 5
E TR6 Windscreen removal Restoration & Tools 2
E TR6 73 TR6 windscreen removal Triumph 8
AltaKnight TR6 TR6 windscreen wipers Triumph 5
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
