General Tech TR6 Transmission Troubles Pops Out of 3rd gear
Got_All_4
I actually am working on my TR250 but several years ago I installed a J type transmission in it. It was purchased in unknown condition however we knew it had been taken apart because of the RTV silicon all over it. It was a mess inside too as whomever did it installed the oil slinger on the outside and under the throw out bearing cover "spigot". It was the first gearbox I've ever worked on. It was completely disassembled. Measured all the tolerances. Ended up replacing al the bearings, layshaft, detent balls and springs and some of the hardened washers. Tested it on the stand and on the road before I closed everything up.
Here's the problem. Particular when down shifting from 4th to 3rd it stays in for a moment then pops out. In some cases you can hold it in and it's fine. Other time even with a lot of force I can't hold it in gear and it pushes it out. Now on the up shift or whenever there is pressure thru acceleration it always stays in. I did disassemble the top cover and replaced all the detent balls, springs and o-rings. I watched a lot of You tube videos and read my manuals as to try to set the spring pressures correctly on the detent balls so I'm not sure I've got them correct. I'm planning to take the cover off and tighten up the detent balls then do a test run and see if it improves or fixes it. Hopefully that works as I don't want to disassemble the tranny if I can help it. Sound like a plan or where do I start?
Got_All_4
Got_All_4
Doing some more research here and I found a tread in 2011 with a similar problem. However 1st and 3rd were both coming out. Some replies are what I'm thinking however no resolution mentioned.
I took a transmission cover off a extra tranny I had (TR4 I think) and mounted it on the 250 J type. Going to take if for a ride later once the streets dry up and see if that takes care of the problem.
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
C TR6 TR6 Transmission Triumph 5
EWD TR6 74 TR6 - Transmission / Shifting gears Triumph 5
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
hondo402000 TR6 New Transmission parts for TR6 Triumph 5
hondo402000 TR6 new TR6 transmission popping out of gear Triumph 6
mgedit TR6 Transmission Question TR6 in TR4 ... will it work? Triumph 4
hondo402000 TR6 Transmission Leak TR6 Triumph 28
hondo402000 TR6 Transmission Seals, TR6, where to get them Triumph 2
hondo402000 TR6 Leaking Transmission solved TR6 Triumph 5
hondo402000 TR6 TR6 Transmission leak Triumph 5
bobh TR6 New TR6 Transmission Conversion Triumph 3
V TR6 Need a Transmission cooler for your TR6? Triumph 4
cmacmillan TR6 Cleaning the transmission on a TR6? Triumph 18
SCguy TR6 Transmission Swap in my TR6 Triumph 14
hondo402000 TR6 TR3 VS TR6 Transmission units Triumph 6
R_Lyle TR6 TR6 Transmission rear seal removal Triumph 4
Paulus TR6 TR6 Speedometer problem in transmission housing Triumph 5
G TR6 [TR6] removal of front transmission seal Triumph 5
Paulus TR6 TR6 Transmission noise when clutch engaged. Triumph 7
J GT6 TR6 Transmission w/OD in a GT6? Triumph 9
Slider748 TR6 Re-installing TR6 transmission Triumph 14
Slider748 TR6 TR6 transmission removal problem Triumph 12
71tr TR6 Transmission Rebuild [TR6] Triumph 2
A TR6 TR6 Transmission Identification ??? Triumph 3
A TR6 TR6 Transmission Rebuild Woes Triumph 2
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
