TR2/3/3A TR6 Transmission Swap Clutch Slave Question
M_Pied_Lourd
Ok. Another bout of troubleshooting for those that have been there, done that.
I have a TR6 tranny in my TR3A.
I have a clutch slave question. Did I read somewhere that the pushrod needs to be shortened or lengthened when doing this conversion?
Cheers
Tush
M_Pied_Lourd
M_Pied_Lourd
Thanks Mike,
I was pretty sure I had read about this problem before. Thanks for finding this thread. It's a big help.
Cheers
Tush
mgedit
Google is your friend. Find it works even better than the search function on most forums.
Cheers, Mike
SCguy TR6 Transmission Swap in my TR6 Triumph 14
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
C TR6 TR6 Transmission Triumph 5
EWD TR6 74 TR6 - Transmission / Shifting gears Triumph 5
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
hondo402000 TR6 New Transmission parts for TR6 Triumph 5
hondo402000 TR6 new TR6 transmission popping out of gear Triumph 6
mgedit TR6 Transmission Question TR6 in TR4 ... will it work? Triumph 4
hondo402000 TR6 Transmission Leak TR6 Triumph 28
hondo402000 TR6 Transmission Seals, TR6, where to get them Triumph 2
hondo402000 TR6 Leaking Transmission solved TR6 Triumph 5
hondo402000 TR6 TR6 Transmission leak Triumph 5
bobh TR6 New TR6 Transmission Conversion Triumph 3
V TR6 Need a Transmission cooler for your TR6? Triumph 4
cmacmillan TR6 Cleaning the transmission on a TR6? Triumph 18
hondo402000 TR6 TR3 VS TR6 Transmission units Triumph 6
R_Lyle TR6 TR6 Transmission rear seal removal Triumph 4
Paulus TR6 TR6 Speedometer problem in transmission housing Triumph 5
G TR6 [TR6] removal of front transmission seal Triumph 5
Paulus TR6 TR6 Transmission noise when clutch engaged. Triumph 7
J GT6 TR6 Transmission w/OD in a GT6? Triumph 9
Slider748 TR6 Re-installing TR6 transmission Triumph 14
Slider748 TR6 TR6 transmission removal problem Triumph 12
71tr TR6 Transmission Rebuild [TR6] Triumph 2
A TR6 TR6 Transmission Identification ??? Triumph 3
A TR6 TR6 Transmission Rebuild Woes Triumph 2
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
