Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning
hcallaway
Can you spray the entire center set (Gears, Bearing - everything intact) with something like brake cleaner to clean it bare?
I will be changing the pinion seal this week. It all looks good and I don't really feel any slack as it is now set up.
I have searched the web and I see some that feel this ok and as usual others that want it completely disassembled.
I really don't want to go that route. Would this be the same as putting it all in a parts washer and then do a final brake cleaner spray. The rear axle housing has already been sand blasted and degreased prior to the blasting.
Rut
I've cleaned a few with kerosene and paint thinner/mineral spirits without harm. I just put it in a bucket standing on its flange and fill it up, rotate it to circulate the fluid and drain until it's clean. I immediately pour whatever oil I have handy and rotate some more and let it sit. I don't know if it does any good, but it makes me feel good.
Rut
regularman
To change the pinion seal, you might as well drop the pinion and replace the bearing. Be sure that any shims are always kept in order. You may get lucky and everything fit back right, otherwise a new crush sleeve is needed for retightening with the correct preload. You can get the numbers off the bearings and they are not that expensive or clean them good and put them back. I would clean the bearings with kerosene or something to get any bad stuff out. Things only get difficult if you lose one of the shims or change out the gearset. I changed my 3.90 (10/39) to a 3.55 (11/39) and that was a real pain and took a lot of time to get the pinion depth correct.
Kim
H
hcallaway
I took the center section to a guy that started working in 1964 at the MG Dealer in Richmond VA. In about 30 minutes the job was competed and even more important I made a friend with a vast amount of knowledge.
He also said I would not do any damage using brake cleaner to flush the center section out. He suggested WD40 to protect it until I am ready to reinstall the pumpkin.
Taz third member Spridgets 4
RAC68 Third *[3rd] Brake Light Austin Healey 11
TR3driver TR2/3/3A Practical Hints for the Maintenance of the Triumph T.R.3[A] - Third Edition Triumph 5
T Adding a third brake-light Spridgets 5
Jim_Stevens TR2/3/3A Newton's Third Law Triumph 6
maxwedge5281 third brake light ideas Austin Healey 34
Tullamore BN1 3 Speed Transmission Third Motion Shaft Disassembly Austin Healey 3
trrdster2000 General Tech Is a third party handling our classified??? Triumph 2
AUSMHLY Stealth third brake light Austin Healey 26
T Third Brake Light Triumph 6
N BJ8 OD disengages in third Austin Healey 3
BabaKahawa Third brake light advice Austin Healey 16
78MGB Third Brake Light MG 6
K Blinking the Third Brake Light? Triumph 28
Nelson Third brake light added Spridgets 18
J Trans popping out of third? Spridgets 4
Gliderman8 Third brake light anyone? Triumph 6
Trevor Jessie Wireless third brake light Spridgets 1
roofman Third brake light wiring Triumph 11
W THIRD BRAKE LIGHT Triumph 8
hondo402000 TR6 TR6 Third brake light Complete, new link to photos Triumph 9
J Spitfire Third brake light added to my Spitfire Triumph 2
G Third Brake Light saves the day, and my butt...... Triumph 39
S THIRD BLOWN HEAD GASKET! please HELP!!!!! Spridgets 43
S THIRD BLOWN HEAD GASKET! please HELP!!!!! MG 9
T Third gear installation best method Spridgets 10
rick_ingram MGB How To Give Your MGB V8 Power - Third Edition MG 4
Russ Austin "Third" release bearing in 6 years! Triumph 8
S Transmission Rebuild for Third Gear Grind Austin Healey 17
MGTF1250Dave Third Brake Light Triumph 9
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
M New Member with an HD8 Carb Question Austin Healey 1
J Member Search? FORUM Navigation Questions 4
S MGB Transmission cross member re-install MG 14
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
NutmegCT Member near Portland Maine? Other British Cars 46
NutmegCT General Tech BCF member in Maine? Triumph 0
Madflyer TR6 I am now a member of the TR Backlight cars Triumph 7
P New member TR2 carpets Triumph 7
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
NutmegCT New member tweak? FORUM Navigation Questions 0
M MGB New Member MG 1
B TR6 New [Old] Member Triumph 2
B TR6 New Member, first post Triumph 1
A Hello from new member, and car identification help request Other British Cars 9
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
G 100/6 Radiator cross member Austin Healey 6
S New Member 1967 Austin Healey 3000 Austin Healey 5
R TR2/3/3A Tie Member for TR-2 Triumph 2
S TR6 Steve new member Triumph 3
