Spitfire Third brake light added to my Spitfire
Scott_Hower
That looks great!
roofman
Yes it does, hope it is high enough to be effective, as the main reason to add it is because the cars are so low to the ground.
RAC68 Third *[3rd] Brake Light Austin Healey 11
T Adding a third brake-light Spridgets 5
maxwedge5281 third brake light ideas Austin Healey 34
AUSMHLY Stealth third brake light Austin Healey 26
T Third Brake Light Triumph 6
BabaKahawa Third brake light advice Austin Healey 16
78MGB Third Brake Light MG 6
K Blinking the Third Brake Light? Triumph 28
Nelson Third brake light added Spridgets 18
Gliderman8 Third brake light anyone? Triumph 6
Trevor Jessie Wireless third brake light Spridgets 1
roofman Third brake light wiring Triumph 11
W THIRD BRAKE LIGHT Triumph 8
hondo402000 TR6 TR6 Third brake light Complete, new link to photos Triumph 9
G Third Brake Light saves the day, and my butt...... Triumph 39
MGTF1250Dave Third Brake Light Triumph 9
TR3driver TR2/3/3A Practical Hints for the Maintenance of the Triumph T.R.3[A] - Third Edition Triumph 5
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
Jim_Stevens TR2/3/3A Newton's Third Law Triumph 6
Tullamore BN1 3 Speed Transmission Third Motion Shaft Disassembly Austin Healey 3
trrdster2000 General Tech Is a third party handling our classified??? Triumph 2
N BJ8 OD disengages in third Austin Healey 3
J Trans popping out of third? Spridgets 4
S THIRD BLOWN HEAD GASKET! please HELP!!!!! Spridgets 43
S THIRD BLOWN HEAD GASKET! please HELP!!!!! MG 9
T Third gear installation best method Spridgets 10
rick_ingram MGB How To Give Your MGB V8 Power - Third Edition MG 4
Russ Austin "Third" release bearing in 6 years! Triumph 8
S Transmission Rebuild for Third Gear Grind Austin Healey 17
Taz third member Spridgets 4
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
