Emergency Brake Doesn't Release
Martinld123
Bronze
Hello, my 1956 Austin Healey 100 BN2 hand brake does not release on the left wheel. The cable is free, but the shoe hangs up for some reason most times now. Not so much in past years.
There is a number on the top shoe, 021579, whatever that means. I bought the car about 12 years ago from someone who had it restored with help of a donor BN1 car, I believe. So it could have some BN1 and BN2 parts. I am starting to think the shoes could be wrong. Any ideas? Thanks, Marty
The slave cylinder should slide freely on the backplate (that's how the e-brake works). Have someone work the e-brake lever and, if the cyl doesn't move that's your problem; otherwise, the shoes could be stuck.
  • BrakeVid.MOV
MikeAH100M
My guess is that it's not just locking up with the hand brake (since the cable is free) but with also with normal braking. Have you noticed the drum getting hot when you drive? I had this problem of the brake not releasing on my BN2 and it turned out that the piston was sticking (and it took 2 tries to get a functional one from Moss!) You also want to make sure that the adjuster is working and adjusted properly. I also found that the adjuster cams on 2 of my brakes had worked looes from the adjusting pin and made adjusting erratic.
Martinld123
Martinld123
Bronze
Thank you, I forgot how the back plate should move. If that is it do you think I could but a few drops of oil on the outside only to help it along?? Thanks I will work on it.
A few drops of penetrating or other light oil on the backplate side of the cylinder, and some 'persuasion,' might do the trick. I put wheel bearing grease--it's tenacious and heat-resistant--on the cyl and backplate where where the cylinder slides and the cyl securing plates during R&R.
Martinld123
Martinld123
Bronze
Thanks for reply. Yes, the drum gets hot so I know problem is there. I will try your ideas but also I was just reminded that slave cylinder has to slide freely. will be working on it. Thanks Marty
I am going to try your idea but I am worried about getting oil on rubber boot. My only option I think.
I think, if your cylinder is stuck you should remove it and find out why--rust, dried crud, improper installation, etc.--or it's likely to happen again. Note how the cyl and its fitment plates go together (it may be incorrect). You can use brake cleaner to remove any oil around the cylinder (I buy the stuff by the case). I think it's a good idea to remove the shoes before you apply any fluids around them; the friction material soaks up fluids like a sponge and no amount of cleaning and scrubbing will remove it (ask me how I know). A thin smear of wheel bearing grease on both sides of the backplate where the cylinder and it's fitment plates slide won't cause any issues.
Martinld123
Martinld123
Bronze
Thanks all that responded. A little lube on both sides did the trick. I am back on the road again. Marty
R TR2/3/3A Emergency Brake Adjustment Triumph 29
I Wanted emergency brake rods from later Spridget Spridgets Classified 0
maxwedge5281 adjustment of emergency brake Austin Healey 4
T TR2/3/3A Emergency Brake Handle Triumph 7
G TR4/4A Emergency brake dust covers Triumph 4
B MGB Dumb emergency brake questions...help requested! MG 5
J TR2/3/3A Dissassemble TR 3A emergency brake handle. Triumph 4
J Emergency brake lever needed Spridgets 2
H Spring for emergency brake MG 0
D Spitfire Spitfire emergency brake assembly - need photos Triumph 3
S Emergency Brake cable FORUM Navigation Questions 0
S Emergency brake stuck MG 12
S Emergency Brake cable MG 6
M Need Some Advice on a BE Emergency Brake Spridgets 13
JPSmit emergency brake light switch Spridgets 6
JPSmit Quick question #2 Emergency Brake Spridgets 1
A Emergency Brake Handle Correct Reassembly Order ? Austin Healey 2
D emergency brake cable Spridgets 2
M Spitfire Removing the emergency brake grip;1979 Spitfire Triumph 0
kodanja Emergency Brake Knob? Triumph 8
S BJ8 Emergency Brake Lever Loose Austin Healey 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
R General TR Emergency hot wire - because you never know whats next Triumph 2
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
W Emergency rotor fix Austin Healey 2
bigjones Installing a spare distributor in an emergency Spridgets 52
RJS Emergency hood/bonnet release Triumph 22
G Emergency...Sorry MG 19
Trevor Jessie Emergency Stop Spridgets 8
jvandyke emergency help needed in Linden, NJ Spridgets 21
Morris Emergency advice needed Spridgets 13
H Triumph Emergency Kit Triumph 18
lreyburn Road Trip Emergency Kit Austin Healey 18
newmexTR3 emergency advice needed! Blown pushrod Triumph 17
RickB FIXED - Distributor removal 'emergency' [not] MG 39
L Emergency Question: Time sensitive Spridgets 4
healeyboz emergency brakes Spridgets 6
Woodie Urgent help...emergency flasher wiring Spridgets 7
T TR6 tr6 topseal emergency! Triumph 8
regularman The spridget long trip emergency tool kit Spridgets 21
ScottTR6 Emergency bonnet release Triumph 12
Woodie emergency flasher switch Spridgets 7
MadRiver Emergency Bonnet Release Install Q's. Triumph 10
I TR6 Emergency parts for TR6 road trip Triumph 6
TR4nut Poor Man's Emergency Bonnet Release - It works! Triumph 5
T Where do I attach a tow line for emergency tow ? Triumph 6
Brosky New "Emergency" Hood Release Kit arrived today Triumph 3
