Spitfire Spitfire emergency brake assembly - need photos
Dono
Hi All,
Assembling the emergency brake system to my restoring 71 Spit. I have the parts, just can't see in any catalog nor Manual how the rear cable attaches to the frame. From the emer brake handle there is a cable that runs back to a cable, running thru the U-shaped part. Then each end attaches to the brake, but supporting return spring and brackets must attach to the frame or body. Anyone have a couple photo closeups at the rear brake drum, center view, and inside the body?
Thanx, Don Missoula, MT djlorenzen@msn.com
guzzul
Re: Spitfire emergency brake assembly - need photo
The rearmost hand brake cable does not attach to the frame. The cable runs through guides on each side of the body, and through that horseshoe shaped equalizer in the middle. In order to get the cable to run through the body guides, you need to remove the nuts and brackets on the end of the cable and thread it through on each side of the body guides.
Have a look at the attached. After threading the rear cable through the body guides and centre-pull guide, you put the brackets back on as shown, and the end pinch-bracket (number 16 in the diagram) attaches to the rear brake actuating lever that is part of the rear brake cylinder. The L-shaped bracket (20) is held between two adjusting nuts, and the spring (12) attaches to it and to the brake backplate.
Hope this helps.
  • 15726.pdf
Dono
Ross - this is perfect. Really helps. One more question; does the center cable juncture attach to the body? Something has to support the pivot arm, that then pulls on the cable as shown in the drawing you sent. Thanks! Don
guzzul
Yes. The front cable (that attaches to the handbrake arm) is connected to a lever that is attached to the body with a bolt. I can't quite recall where it mounts now, but I think it should bolt to the underside of the body, just in front of the differential.
That lever is connected to a u-shaped equalizer (or compensator it may be called), that the rear brake cable loops through. I think the only bolt that actually attaches the brake cable assemblies to the body of the car is that one pivot-lever bolt.
Send me a PM and I will send you a page from the Leyland manual that should help. Its from a 1500 but should be pretty much the same at the back end.
M Spitfire Removing the emergency brake grip;1979 Spitfire Triumph 0
M Spitfire Spitfire underbonnet emergency light Triumph 2
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
