Spitfire Spitfire lighting issues
Dnickels
Hello- Looking for help with some lighting issues on a Spitfire Mk2
Head lights work when car is off and running
Break lights only work when car is running
Dash Lights work when car is running
Front left flasher works when car is running
Tail lights/Running lights do not work.
I cleaned the rear connections and made sure the bulbs are good and making contact. Also found what I think is a ground wire (wire loop) by the left rear tail light not connected, I connected it to the frame in the trunk. This did nothing to solve the above problem.
Any suggestions will be appreciated!
UltimateQuestion
The wiring to the rear of the car runs under/near the driver's seat (LHD USA). check that it hasn't been chafed or cut. Mine did and would blow a fuse every time I drove it.
Trevor Triumph
When you say the car is running, is the engine actually running or the ignition is "on?"
For some reason, Triumph thought having headlights hot whether the ignition was off was a good idea. That brake / stop lights work only when the ignition was on was a good idea.
The front turn signal wire connection may drift apart at the front of the car. Check all the connections going to the bonnet. Both the power and ground can separate work loose and work intermittently. Running lights, meaning what some call "parking lights" rear license plate light, and tail lights on the same circuit - red, I believe. Check the fuse, fuse box, and connections on the scuttle tucked away so you have to stand on your head to see them. Connections to the rear part of the harness are also hiding to the left, near the windscreen post.
When chasing problems this spring we started with the battery and cleaned and secured every connection to each light bulb in the car. Time consuming for sure, but every electrical item worked, all lights, horn, overdrive.
It is my belief the electricity, auto electrics in particular, is black magic. I always feel so good when I have tracked down electric gremlins.
Dnickels
Dnickels
T- Thank you for the feedback, your advice is helpful, I will continue to figure out this car. To clarify the headlights are hot all the time and yes the break lights only work with the ignition on and when the engine is running.
U Spitfire Lighting issues on 1980 Spitfire Triumph 2
R Spitfire GT6/Spitfire Lighting Questions Triumph 10
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
