Spitfire GT6/Spitfire Lighting Questions
Richter12x2
Trying to make this easy to find for future searchers too, so bear with me: troubleshooting, wiring, switches,
Ok.
Still assembling the GT6 project, and in true British fashion, the wiring is a bit dodgy. To give an idea, when I first started, I wired it all up, the correct wires were all connected color for color, and everything looked like it belonged where it was connected. All the negative leads from all the lights on the front were connected together into the harness instead of to the chassis, as the book said.
So I flip the light switch on, and one flasher lights up solid, and one clear bulb lights up solid. Nothing else happens.
Figuring I need to clean up some connections and replace some bulbs, I go to the non-lighting clear lamp on the front, and give it a twist, then everything goes out and the headlights come on. There was also a good bit of fun while testing the brake lights, when I let all the smoke out of the taillights. Apparently the insulating sheet in the taillight had gone.
Anyway, fun story over and I've made some progress. Brake lights work fine and tails come on with the light switch, but I've got ('67 GT6) a pair of reds back there that haven't lit yet. What causes those to come on?
Also, on the front, I turn the light switch on the dash down, then the stalk on the right side of the column is Off then Lo then Hi going from top to bottom. Orange lights are flashers, what causes the white lights to come on?
In retrospect, it might have been useful to play with all this and see how the switches worked before disassembling the whole thing.
Thanks in advance!
foxtrapper
The light sockets on the Spitfire are remarkably horrible. Very prone to failing as they are pressed together. Beware also the bullet connectors and the dirty connection.
R
Richter12x2
Yeah, the bullet connectors are really bad. They don't appear to have actually been, you know CONNECTED at any point in time, they just pulled a few strands of wire through the hole at the end and called it good.
I found that I can get the bullet connectors from the auto parts store and crimp them on good and solid, then use a jewelers screwdriver to widen the tips, and they fit nice and tight now.
Andrew Mace
The round red lights at the rear (L691 or L692, usually, on a GT6) are flasher (turn signal) lamps only.
Those white lights (usually L594 glass or "beehive" lenses) are the side lamps or what we in the US usually call parking lamps. They should come on with the first position of the light switch, and they should remain on when headlamps come on (unlike most American cars pre-1968 or so).
And for whatever it's worth, the "power" wire from a running lamp usually is red, while the "power" wire from a flasher lamp is usually green. With the flasher lamps, the green connects to a green-with-red wire for LH side flasher and to a green-with-white wire for RH side flasher.
Does that help?
Oh, and I admit that some of the lamps on a Spitfire or GT6 can get a bit dodgy, but the only ones I ever routinely had trouble with were the taillamps. With only one screw holding the lamp and a lens gasket that tended to dry out and lose most all usefulness as such, I spent a few minutes every several months removing the bulb, cleaning the two contacts on the lamp and cleaning up the bulb itself...and then I was good to go again for awhile! :wink:
R
Richter12x2
Perfect, that's way helpful! Now, black from all of these and the headlights is supposed to connect back to the black wire in the harness coming forward, NOT to the chassis, is that right?
R
Richter12x2
Is there a way to do it without making the lenses all black like the Hondas do? :laugh: Actually found a good deal on a set of taillights from ebay from a gentleman in New York area, I think. He sent me two that are in great condition.
I think the ultimate classic must be an Arizona car with Northern wiring. Hot and dry is great for rust, but hard on wires.
R
Richter12x2
Andrew Mace said:
Right. Black is always ground, but there often is provision (such as in this instance) in the harness for ground wires from lamps and such. (Not that you couldn't use additional or alternate grounds, but....)
Ah cool, I wondered if there was any electrical reason for them to want the ground returned that way, like switching ground or something. Something's happening that makes the headlights want to short back to ground across these other bulbs. With great vigor once the horn wiring (with it's grounding ring) is installed. Breaking them out should help me isolate whatever's happening.
UmmYeahOk
booley said:
Richter12x2 said:
... when I let all the smoke out of the taillights.
that smoke will have to be replaced if you expect ANY of the lights to work properly...
...umm... ...you're being serious right? Cuz I found this and got scared:
We have liquid smoke in the kitchen, but we were saving it for the steaks.
R
Richter12x2
All lights are now working! It's amazing how much a 45 year old blue with red stripe wire resembles a 45 year old black wire when making ground connections in dim light, and what a difference it makes to the function of the lighting circuits.
Kinda interesting though, you can switch from a positive ground to negative ground car with the flip of your headlight switch. :laugh:
Now I just have to clean up one of the connections and find out what's wrong with the reverse switch and we should be good to go!
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
David Townsend GT6 GT6 and Spitfire Fine Art Prints Triumph 0
anarchy99 GT6 Body differences between gt6 and spitfire... Triumph 12
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
D Spitfire GT6/Spitfire heater Ducts Triumph 3
W Spitfire Spitfire or GT6 wheels Triumph 1
W Spitfire Spitfire / GT6 bonnet Question Triumph 7
jollyroger Spitfire GT6 engine in 76 Spitfire, source for trans cover Triumph 6
UmmYeahOk Spitfire Misc GT6/Spitfire Questions Triumph 9
Reh Spitfire GT6/ Spitfire to 4x100 Triumph 5
UmmYeahOk Spitfire GT6/Spitfire Heater Box Mounting Triumph 12
UmmYeahOk Spitfire GT6/Spitfire E-Brake Button Triumph 7
Reh Spitfire GT6 with Spitfire hood. Triumph 7
B Spitfire spitfire transmission conversion to GT6? Triumph 5
Reh Spitfire GT6 and Spitfire look alikes Triumph 3
K Spitfire GT6 Rad same as Spitfire Rad? Triumph 4
T Spitfire Spitfire GT6 cover Triumph 2
svtmikey Spitfire GT6 and Spitfire Dual brake M/C differences Triumph 9
WedgeWorks Wedge Ultimate TR6, GT6, Spitfire & TR8! Triumph 11
eschneider Spitfire spitfire GT6 rubber source??? Triumph 7
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
TheAssociate Spitfire Spitfire and GT6 diffs... Triumph 8
nathandarby67 Spitfire Spitfire / GT6 Dashboard Help Triumph 13
CinneaghTR Spitfire Spitfire/GT6 Owners! Get your Silverstone Wheels! Triumph 12
S Spitfire GT6 Roadster or Spitfire 6? Triumph 27
bcliff Spitfire GT6/Spitfire parts need a new home, FREE! Triumph 4
G Spitfire Lost & Found: Spitfire & GT6 Magazine *DELETED* Triumph 5
F Spitfire Differences between Spitfire and GT6 Chassis Triumph 2
TR4 Spitfire 1/43 Scale Model of TR4, GT6 and Spitfire Triumph 5
D Spitfire Best place to find a Spitfire/GT6? Triumph 9
Beavis Spitfire GT6 and Spitfire aerodynamic drag coefficient Triumph 11
KLUTZ Spitfire Spitfire / GT6 Magazine at Chapters Books ! Triumph 3
78Z Spitfire 70 GT6 parts better than 74 Spitfire parts? Triumph 4
M Spitfire GT6 or TR6 in a Spitfire? Triumph 14
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
ccw283 GT6 GT6 fender flares Triumph 1
B GT6 trying to ID my New Car. GT6 Triumph 6
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ‘72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
