Spitfire GT6 or TR6 in a Spitfire?
MrP
Member
I was just wondering if it would be possible to drop say a GT6 or TR6 6 cyl motor into a Spitfire? Has anyone ever seen something this done before?
MrP
G
I've heard that the GT6 motor is a relatively easy swap. You know the GT6 is practically a spitfire. I know someone who has a GT6 motor here in Memphis if your interested. I believe its complete except for carbs and transmission.
[ 01-16-2004: Message edited by: David Kiehna ]</p>
78Z
The easiest way too do this would be get a rusted GT6 and swap the Spitfire body onto a GT6. Then you get the brakes upgrade too. The weight distribution takes a bit of a hit though as the inline six is almost as heavy as a Ford 302 V8! Oh you need the GT6 bonnet/hood as well for the carbs and valve cover to clear.
Its a pretty popular swap so lots of info online. Try https://www.gt6.com/ as a start. Its got a nice webzine.
The TR6 motor doesn't fit as easy. Differs externally from GT6 in oil and carbs at least.
Administrator
Boss
Hmmm, a 6 cylinder Spitfire! Now there's an idea! I bet a GT6 wouldn't be too hard to drop into a Spitfire. Don't they have basically the same chassis forward of the firewall? I may have to look into that mod myself one of these days
[ 01-16-2004: Message edited by: Basil ]</p>
Baxter
I know it's trickier than you first think.. there's quite a few little differences between the two, and some fairly major ones. The frames are somewhere between slightly and very different, depending on exactly which year.. gas tanks are in different locations.
That said, it's a relatively simple swap, and it's certainly been done many many times.
G
My friend up the road dropped a GT6 engine into his TR3 resto. Stock-looking little bullet gives my souped up TR6 a run for the money...
Bill
As 78Z said, there are several Spit/6' out there. The spifire tub on the GT6 frame is the best way to do the conversion, makes it a very fun car. It just so happens I have a project that was started that way. Good GT6 frame,bonnet and engine with the spifire body tub sitting on the frame, if anyone wants it I will let it go for $650. TR6's are my first love but I will try to save all the LBC's I can.
Marvin
M
MrP
Member
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by David Kiehna:
<hr></blockquote>
Thanks for the offer, but I couldn't afford it right now anyway, I was just curious. It is something I might like to try some day when I'm not so poor
MrP
spit6 guy
Member
I have done the GT6 engine into the spitfire and
I will tell you that swappimg the bodies is the
way to go because I did it the other way and had a tough time getting the rear end in corect; so I finaly changed the frame to get it right. The only
thing that I would do is get the rear shock mount extention so that the shocks mount on the frame, not the body. After that the rest is just changing the gauges, the brake cables, and master cylinder because they are diffrent sizes.
kurt
Administrator
Boss
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by BOXoROCKS:
I did the Spit/TR6 conversion, I would post a pix but dont know how<hr></blockquote>
Look at the tutorial under the "Help" menu above and select the "How do I post a picture" link. It will show you with actual forum screen shots how to do it.
Administrator
Boss
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Eric:
There's lots of info on Spit/GT6 conversions at
<hr></blockquote>
Excellent! Thanks for the link! I have dual webs on my Spitfire and am thinking of removing one and going with a single (I think two is too much carb for my setup). Great to see a reference on proper jet sizes, etc.
BOXoROCKS
Well... Thanks for the tip. I read the tutorial, but I am one of those guys who doesn't think his life is all that interesting enough, to have a web page. Hopefully, the only time that I will be in print is on the obits page.
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
WedgeWorks Wedge Ultimate TR6, GT6, Spitfire & TR8! Triumph 11
T GT6 GT6 and TR6 gearboxes interchange? Triumph 6
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
tr6nitjulius Spitfire TR3*3 TR4*2 TR6*7 Spit*2 GT6*1 Others*2 Triumph 5
glemon GT6 TR6 GT6 Quoted HP More Triumph Trivia Triumph 1
W GT6 GT6 / TR6 Rotor Options Triumph 2
G GT6 Can I put a GT6 balancer [crank pulley] on a TR6? Triumph 2
T GT6 Toyota caliper swap for GT6 like TR6? Triumph 3
hymodyne GT6 TR6 in a GT6 Triumph 9
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
F GT6 GT6/TR6 Engine Painting Procedure... Triumph 3
SCguy GT6 GT6 or TR6 in Nor Cal Anyone interested? Triumph 1
B GT6 Isuzu Trooper Gear reduction starter for TR6/GT6? Triumph 5
F GT6 TR6 dual exhaust manifold on GT6 engine? Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
GT6_Mark GT6 GT6 TR6 etc Oil Filter By-Pass Valve Pressure Triumph 2
S GT6 GT6 Head on TR6 Block Triumph 1
F GT6 GT6 Clutch Kit advice, as bad as the TR6 kits? Triumph 5
Alan_Myers GT6 Free GT6 body shell, SF Bay Area. TR4 & TR6 Triumph 1
bobh GT6 GT6 Crank in a TR6 Block Triumph 4
michalotti_tr GT6 Engines: TR6 vs GT6 Triumph 14
J GT6 TR6 Transmission w/OD in a GT6? Triumph 9
S GT6 GT6 engine in a TR6 Triumph 3
svtmikey GT6 TR6 engine parts in a GT6 Triumph 9
S GT6 GT6/TR6 rocker arm identification and questions. Triumph 0
S GT6 GT6/TR6 rocker shaft oil problems. Triumph 5
nathandarby67 GT6 Are GT6 oil filters the same as TR6? Triumph 1
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
ccw283 GT6 GT6 fender flares Triumph 1
B GT6 trying to ID my New Car. GT6 Triumph 6
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale β€˜72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
idlehands Wanted GT6+ Triumph Classifieds 11
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
B Wanted wing windows gt6 Austin Healey Classifieds 0
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
