GT6 TR6 GT6 Quoted HP More Triumph Trivia
glemon
About 1972 or so the quoted HP for the GT6 dropped from 95 to 79. Some if not all of the change was attributed to a change from using Gross to SAE net HP ratings, something that I think most if not all manufacturers did when quoting HP in the USA about this time.
My question is why didn't the TR6 see a similar drop, quoted HP for the TR6 stayed in the 100+ range in the USA throughout production.
I know they did some changes to camshaft and exhaust through the TR6 production, was this enough to more or less overcome the change from gross to net HP quoted? I am guessing not or the later cars actuallyy would have been a litle faster than the early ones. Or maybe Triumph fudging a little to keep the TR6 over 100 quoted HP. But if they fudged on the TR6 why not on the GT6?
Any knowledge of this out there? or discussion/educated guesses?
UltimateQuestion
TR6 = 2.5 Liters
GT6 = 2.0 Liters
Could have something to do with it
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
T GT6 GT6 and TR6 gearboxes interchange? Triumph 6
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
tr6nitjulius Spitfire TR3*3 TR4*2 TR6*7 Spit*2 GT6*1 Others*2 Triumph 5
W GT6 GT6 / TR6 Rotor Options Triumph 2
G GT6 Can I put a GT6 balancer [crank pulley] on a TR6? Triumph 2
T GT6 Toyota caliper swap for GT6 like TR6? Triumph 3
hymodyne GT6 TR6 in a GT6 Triumph 9
WedgeWorks Wedge Ultimate TR6, GT6, Spitfire & TR8! Triumph 11
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
F GT6 GT6/TR6 Engine Painting Procedure... Triumph 3
SCguy GT6 GT6 or TR6 in Nor Cal Anyone interested? Triumph 1
B GT6 Isuzu Trooper Gear reduction starter for TR6/GT6? Triumph 5
F GT6 TR6 dual exhaust manifold on GT6 engine? Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
GT6_Mark GT6 GT6 TR6 etc Oil Filter By-Pass Valve Pressure Triumph 2
S GT6 GT6 Head on TR6 Block Triumph 1
F GT6 GT6 Clutch Kit advice, as bad as the TR6 kits? Triumph 5
Alan_Myers GT6 Free GT6 body shell, SF Bay Area. TR4 & TR6 Triumph 1
bobh GT6 GT6 Crank in a TR6 Block Triumph 4
michalotti_tr GT6 Engines: TR6 vs GT6 Triumph 14
J GT6 TR6 Transmission w/OD in a GT6? Triumph 9
S GT6 GT6 engine in a TR6 Triumph 3
svtmikey GT6 TR6 engine parts in a GT6 Triumph 9
S GT6 GT6/TR6 rocker arm identification and questions. Triumph 0
S GT6 GT6/TR6 rocker shaft oil problems. Triumph 5
M Spitfire GT6 or TR6 in a Spitfire? Triumph 14
nathandarby67 GT6 Are GT6 oil filters the same as TR6? Triumph 1
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
Hawk813 TR6 TR6 Brakes Triumph 5
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
