TR6 TR6 & GT6 Flywheel, Clutch question:
toysrrus
Howdy Folks,
A friend of mine has a "GT6 Spit". He would like to couple a "TR6" Flywheel, Pressure Plate & Disc. to the existing GT6 drivetrain.
His question is: Would this be a direct bolt on or What modifications would have to be done?
Thanx Much,
Russ
HerronScott
I'm not an expert here, but the input shaft is different between the Spitfire/GT6 and TR6 transmission so I don't see how this could work.
Scott
tomshobby
I purchased a new '67 GT6. The clutch was one of three weak parts of the drive line along with the transmission and rear diff. If I dropped the clutch at higher rpm's the clutch would slip so bad that the car would not even move. Replaced the clutch and pressure plate 3 times with the same result.
I never had a chance to compare a TR6 clutch/fly wheel so I don't know if it will even fit the space, the ring gear, and the crank shaft. Or stand up to the GT6 rpm range. But if it does I would have done it especially with an aluminum fly wheel. The original steel flywheel in my TR6 was about 26 pounds and my aluminum flywheel is about 1/3rd that amount. Made a huge difference in the TR6.
trrdster2000
Russ, small problem, even if the input shaft would fit, which I feel sure it will, you still have a GT6 clutch plate, because of the splines on the input. You can still add the pressure plate from the TR6. Since you have gone to a lot of work making the Spite 6, why not use the front casing off the GT6 tranny and figure a why to add a Ford T5 to the back end of it. Just a little dream I had, even saved a GT6 bell housing, just in case I ever get time.
Wayne
toysrrus
toysrrus
Hi Folks,
The gent I was referring to has made a decision to go ahead & buy the "TR6" parts & try to couple them to his "GT6". He was told by other folks that he should not have a problem?!?!?!? "LOL"!!!
I spoke to a gent at "Moss Mtrs" (DJ is his name) & he being an owner of a "GT6" and the "Triumph" Guru @ Moss said; It is "NOT" a direct bolt on & there are lots of things that would have to be modified.
We`ll see. Thanx to all for the info.
Regards, Russ
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
T GT6 GT6 and TR6 gearboxes interchange? Triumph 6
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
tr6nitjulius Spitfire TR3*3 TR4*2 TR6*7 Spit*2 GT6*1 Others*2 Triumph 5
glemon GT6 TR6 GT6 Quoted HP More Triumph Trivia Triumph 1
W GT6 GT6 / TR6 Rotor Options Triumph 2
G GT6 Can I put a GT6 balancer [crank pulley] on a TR6? Triumph 2
T GT6 Toyota caliper swap for GT6 like TR6? Triumph 3
hymodyne GT6 TR6 in a GT6 Triumph 9
WedgeWorks Wedge Ultimate TR6, GT6, Spitfire & TR8! Triumph 11
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
F GT6 GT6/TR6 Engine Painting Procedure... Triumph 3
SCguy GT6 GT6 or TR6 in Nor Cal Anyone interested? Triumph 1
B GT6 Isuzu Trooper Gear reduction starter for TR6/GT6? Triumph 5
F GT6 TR6 dual exhaust manifold on GT6 engine? Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
GT6_Mark GT6 GT6 TR6 etc Oil Filter By-Pass Valve Pressure Triumph 2
S GT6 GT6 Head on TR6 Block Triumph 1
F GT6 GT6 Clutch Kit advice, as bad as the TR6 kits? Triumph 5
Alan_Myers GT6 Free GT6 body shell, SF Bay Area. TR4 & TR6 Triumph 1
bobh GT6 GT6 Crank in a TR6 Block Triumph 4
michalotti_tr GT6 Engines: TR6 vs GT6 Triumph 14
J GT6 TR6 Transmission w/OD in a GT6? Triumph 9
S GT6 GT6 engine in a TR6 Triumph 3
svtmikey GT6 TR6 engine parts in a GT6 Triumph 9
S GT6 GT6/TR6 rocker arm identification and questions. Triumph 0
S GT6 GT6/TR6 rocker shaft oil problems. Triumph 5
M Spitfire GT6 or TR6 in a Spitfire? Triumph 14
nathandarby67 GT6 Are GT6 oil filters the same as TR6? Triumph 1
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
