GT6 GT6 Clutch Kit advice, as bad as the TR6 kits?
Flinkly
I've read plenty on the hit and miss of clutch kits available for the TR6 since i've been a part of the triumph world. since i'm in the middle of a restoration, i'm going to be replacing the original clutch with a complete kit, but the TR6 problems make me wary of a change. Do i have to look out for the same problems and what do people think about the GT6 options available?
I guess i need some people with an informed opinion on what to get and who i should buy from.
Andrew Mace
Fortunately, the clutches between GT6 and TR6 are different not only in size but in actuation; about the only thing they are are the same or similar clutch slave cylinders. Part of the "classic" problem with TR6 clutches stems from what may not have been the best and most durable bit of engineering ever to originate in Coventry, England: that being the throwout bearing mechanism. The rest of the problem nowadays seems to be in design and quality of pressure plates in particular: what is currently supplied by the OEM as a correct replacement (read: it fits, but....) is apparently nowhere near as good as it was back when the cars were new.
All that said, I always was very happy with Laycock brand clutches for the GT6, but I don't believe they are available new (although NOS bits turn up from time to time). I think the currently supplied new clutches for the GT6 are ok, though.
tomshobby
When I had my '67 GT6 in the 60's and 70's I could not find a clutch/pressure plate combination that would lock up under more aggressive power. I always felt they were under size for the power of the engine. Of course it did save tires and probably the tranny and rear diff! Although I did break both of them.
F
Flinkly
i still have the clutch i took off and it is an original laycock, should i go against my better judgement and keep the clutch setup, or try my luck with a vendor clutch kit?
spitbits does have a deal on a different kit then the big three, but since this is my first clutch buy for the gt6, i have no idea what is quality and what isn't.
i'll probably buy the coventry classic clutch kit from spitbits since i have an order to make from them soon.
V
vagt6
You might call Nigel (Cosh, the owner) at SpitBits and discuss with him. He's a true LBC enthusiast and an expert on these cars. He'll give you a reliable assessment.
I installed the kit from SpitBits in my GT6, no problems. I didn't thrash my car, though, so I'm probably not a good example for folks who like to push the limits.
Let us know, and good luck!
dklawson GT6 GT6 Clutch Failure - Where to Look First Triumph 16
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
19_again GT6 GT6+ clutch questions Triumph 4
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
ccw283 GT6 GT6 fender flares Triumph 1
B GT6 trying to ID my New Car. GT6 Triumph 6
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ‘72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
idlehands Wanted GT6+ Triumph Classifieds 11
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
B Wanted wing windows gt6 Austin Healey Classifieds 0
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
H GT6 GT6+ seat panels Triumph 2
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
R GT6 Looking to purchase GT6 Rust repair question? Triumph 4
R GT6 Triumph GT6, basic work estimates Triumph 76
glemon GT6 GT6 Getting Some Recognition Triumph 8
R For Sale Triumph GT6 3.27 rear Triumph Classifieds 2
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
brgrmyster GT6 1968 GT6 MK. 1 original emissions lines Triumph 0
brgrmyster GT6 Original GT6 Mk 1 cooling fan Triumph 24
Spritey For Sale .. or [TRADE] Early GT6 seats Triumph Classifieds 1
R Wanted Overdrive gearbox for GT6 Triumph Classifieds 0
David Townsend GT6 GT6 and Spitfire Fine Art Prints Triumph 0
Steve GT6 Spotted 2
T GT6 Opinions on what a rust free GT6 is worth Triumph 22
T GT6 GT6 and TR6 gearboxes interchange? Triumph 6
trrdster2000 GT6 Been a while on a GT6 transmission. Triumph 2
R GT6 Early Gt6 Pushrod tubes Triumph 14
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
anarchy99 GT6 Rear window fitment for gt6 Triumph 1
anarchy99 GT6 Body differences between gt6 and spitfire... Triumph 12
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
TR6BobNF GT6 GT6+ Parts for Sale in Newfoundland, Canada Triumph 0
