GT6 Fuel Pump Leaking at out port GT6 MK3
Andymk3
Hello,
Ordered a repro fuel pump 4 yrs ago from Victoria British. Have put about 100 miles on the car I am slowly restoring.
Got home from a 30 mile drive. Next day I start the car and I have gas leaking badly out of front carb and at the fuel pump out port.
Removed the carb bowl and maybe the float was stuck. In any event carb doesn't leak when I put the bowl back on.
Can't say the same about the fuel pump. Been reading were the compression fitting may be the issue and the sleeve somehow, but the fitting, I believe is original. Have ordered a tube nut and sleeve from TRF but part is back ordered.
I also see where some say it's good to rebuild the fuel pump. I see there is a video on how to do that.
Any thoughts on why one thinks it's leaking? Also, rebuilt kit for my AC Delco U type carb would might be best purchases from???
New member,
Andy
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
H TR2/3/3A Leaking Fuel Pump Sediment Bowl Triumph 5
D Leaking fuel pump connections Triumph 32
D Leaking fuel pump Spridgets 7
J New SU Fuel Pump - Gas leaking out of carb vents Austin Healey 24
N Fuel Pump Leaking MG 32
floyd leaking fuel pump Triumph 6
drooartz Leaking fuel pump Spridgets 36
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
