TR6 TR6 fuel pump question - glass bowl pump correct?
pburress06
Just getting this 1971 TR6 running after sitting for 6 years. The fuel pump wasn't working and I had another fuel pump in the spare parts box so I swapped it. This fuel pump works. But, the original fuel pump has a metal bowl on top and the replacement one has a glass bowl. If this pump is not for this year or is for a different model TR, will it cause problems with inadequate flow or anything like that? The carbs need rebuilding so I haven't had a chance to run it on the road for a while. Thanks.
glemon
My '68 TR250 has a metal bowl. I can't imagine that they went from metal back to glass later. As I am sure you know, the earlier glass pumps work off the same principal (a lever pushed against a lobe on the cam) but no idea if depth, throw, etc., are the same from what I assume is a four cylinder TR pump to the six cylinder item.
Gliderman8
Never heard of or saw a glass bowl for a TR6 fuel pump either.
pdplot
I Googled the question. Apparently there was (is) a glass bowl fuel pump for TR2, TR3 and TR4. Whether this can be made to fit and work on a TR6 is a question of try and see. You may have discovered something.
P
pburress06
It works. I guess I need to research the cfm output of this earlier Triumph pump as compared to the stock TR6. It definitely looks cooler which is a plus.
NutmegCT
Just my two cents, but ... you mention " ... I had another fuel pump in the spare parts box so I swapped it. "
So it wasn't specifically a TR6 pump?
It might fit in the opening, but how do you know the action arm isn't damaging something (or being damaged) inside the engine? Proper size, proper movement, etc.
I don't think I'd want that risk. It might look cool, but the results might not be cool! I'd think there must have been a reason for Standard Triumph to fit a different pump for engines after the TR2/3.
Tom M.
Madflyer
I have had a TR 4 and a 250 and TR6 now. I have not seen glass on a TR. If it was on a GT 6cyl it would work. My question is does it have a lever on the pump to put fuel up to carb before starting. I put a wire to my pump so I do not have to reach down to pump it up. The guys with trip Weber's might need a bigger pump sold at Summit Madflyer
F TR6 TR6 Fuel Pump Priming Triumph 11
sundown TR6 1973 TR6 fuel pump Triumph 4
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
I TR6 TR6 fuel pump - how do I replace these? Triumph 18
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
BobbyD TR6 TR6 Fuel Pump Triumph 1
Brosky TR6 Fuel Pump Kit for TR6 Triumph 3
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
J TR6 Just another whining TR6 fuel pump again? Triumph 19
SCguy TR6 How can you tell if your TR6 fuel pump is working? Triumph 4
G TR6 Free OE TR6 Fuel Pump.....................8 bucks. Triumph 2
V TR6 TR6 Fuel pump spares Triumph 8
padjo TR6 TR6 Fuel Pump Triumph 1
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
B TR6 TR6 Fuel Filter keeps clogging Triumph 9
D TR6 1976 TR6 Fuel Lines Triumph 7
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
G TR6 TR6 fuel tank fitting size. Triumph 14
Gliderman8 TR6 Troubleshoot a TR6 Fuel gauge problem Triumph 36
M TR6 TR6 Fuel Delivery Issue Triumph 18
I TR6 TR6 fuel pipe nut source? Triumph 5
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
T TR6 tr6 fuel sending unit Triumph 5
G TR6 TR6 Fuel Injection ? Triumph 8
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
DNK TR6 TR6 fuel lines. Triumph 20
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
B TR6 71 TR6 Fuel Tank firewall? Triumph 6
I TR6 TR6 Fuel gauge help Triumph 7
E TR6 TR6 Fuel / Mixture ? Triumph 4
71tr TR6 fuel line TR6 Triumph 2
V TR6 Oil and Fuel for TR6 Triumph 6
I TR6 Fuel injection for TR6 Triumph 4
71tr TR6 fuel line TR6 Triumph 6
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
I TR6 fuel lines for 69 TR6 Triumph 3
Tullamore TR6 TR6 Fuel Leak Triumph 4
Morris TR6 TR6 Fuel Injection Triumph 21
M TR6 TR6 FUEL TANK VENT PIPE Triumph 3
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
