TR6 1973 TR6 fuel pump
poolboy
In the manual I have it says 1.5 to 2.5 psi
Pressure is not that important as long as it's less than 4 psi, all the pump has to do is keep enough fuel in the carbs' float chambers.
If you want to check the pressure though use a vacuum gauge. The needle swings one way for vacuum readings and swings in the opposite direction for pressure readings.
Just connect it where I have the cutoff valve. If the float chambers have gas in them, the engine will start and run for a while as you look at the gauge.
Geo Hahn
If you ever have occasion to watch the fuel coming out of a line you might be more likely to call it 'spitting' than 'pumping'. It emerges as spurts rather than a gentle stream.
The pump's job is just to keep the bowls full, hence the low pressure -- high pressure would risk overpowering the needle & seat valve that is closed by the float in a full bowl.
TR3driver
Great Pumpkin - R.I.P
If you want to check the pressure while fuel is flowing, use a tee to connect the gauge and the carbs at the same time. Lots of problems show up as a loss of pressure at higher flow rates. I've even been known to use a hose long enough to bring the gauge out and prop it under a wiper, so I can read it while driving at high speed.
PS, the 'spurting' is because the pump only outputs fuel during every other engine revolution. The rest of the time, it is sucking fuel from the tank.
Tybalt
If you are trying to diagnose a potentially bad fuel pump, bear in mind that the fuel level in the tank will have an impact. With the fuel tank mounted as high as it is in these cars having a full tank can mask a dying fuel pump on the suction side. I've limped more than a couple of these cars home by keeping the tank relatively full and avoiding steep uphills in order to keep the fuel flowing.
You might consider doing the test with the car level and then with the front end elevated and note any differences in the results.
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
M TR6 1973 TR6 - broken choke cable Triumph 6
M TR6 1973 TR6 Coolant Type? Triumph 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
sundown TR6 1973 tr6 Triumph 0
sundown TR6 1973 tr6 oil pressure light Triumph 3
sundown TR6 1973 TR6 flasher unit Triumph 1
sundown TR6 1973 tr6 wiring Triumph 21
jerrybny TR6 1973 TR6 Seat Covers Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
JoeC TR6 1973 TR6 parts car Triumph 2
jerrybny TR6 1973 TR6 Front License Plate Bracket Triumph 1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
S Stag 1973 Triumph Stag Triumph 2
R TR6 1973 Final drive issues Triumph 5
