TR6 1973 TR6 oil between the head and engine block?
sundown
I took a spirited ride yesterday got home and lifted the hood and noticed what looks like engine oil around the plugs and some on the block. The car runs fine no smoking and a lot of power. Nice steady vacuum reading at 17. It doesn't look like it's coming from the valve gasket I can't see any oil on the side of the head where it might leak down. Thanks for any input
Geo Hahn
Not that familiar with TR6s -- but I would think an oil leak between the head and engine would be pretty localized and not be on the plugs.
...noticed what looks like engine oil around the plugs and some on the block...
Coolant, once it is combined with dirt or grease in the area, can look a lot like oil. If you clean the area and cause the leak to recur you may be able to better identify what it is -- which is what you must be sure of to identify what is going on.
titanic
If the oil is in the spark plug "wells", I would think that if would have to come from the valve cover or the spark plugs. If at the head/block interface, maybe some blow by from the crankcase. Oil leaks on that side of the head seems to be pretty common with TR6s. I cured mine by coating the head gasket with sealer when the head was removed for work. Since you noticed the problem after a "spirited drive", that would seem to indicate crankcase pressure from blowby and/or a problem with venting.
Berry
poolboy
That's a fairly common place for oil to show up when there is inadequate relief of crankcase pressure.
Len Reckenberger specifically mentions that scenario in his "SIX TECH" manual.
The TR6 has a "closed crankcase ventilation system" No vent in the oil filler cap.
The pressure from blowby would normally be taken care of by the 2 evacuation ports on the right hand side of the twin 175 ZS carbs in the post 69 cars.
Gliderman8
I actually had oil coming out of the riser tube for the dip stick on my '73. I followed poolboy's recommendations for crankcase ventilation and my oil problems went away!
sundown
sundown
I do have the crankcase venting into the carbs. Although the only vent going to the CC is the gas tank. I did way with the tee that goes from the carb and crankcase that feeds into the CC could this be a problem? Could be another way to vent the blow by?
poolboy
No..I don't think that's the issue. Instead of having the carbs suck on the valve cover and the cc, you have the carbs just sucking on the valve cover which should make the relief of crankcase pressure by the carbs even more effective.
There is another way, which does not use the evacuation ability of the carbs.
Some people with ZS carbs have used it, so have people who replaced their ZS carbs with SU's or Weber DGV carbs.
This :
https://www.goodparts.com/shop/index.php?productID=253
Installed like so:
When I rebuilt one of my engines, I had oil show up where you described, but after the rings broke in and sealed, it stopped.
Your engine isn't new, is it ? Or was this something that just started 'out of the blue' ?
sundown
sundown
I did just replaced the valve cover gasket after I adjusted the valves . The engine has been rebuilt rings,bearings, thrust washer, etc not too long ago maybe has 10,000miles on it. I just started to notice this issue
poolboy
It might be a good idea to do a compression test..see if the rings are containing the pressure or allowing more blow by than normal.
sundown
sundown
I did a vacuum test and the needle was steady around 16-17 indicating from the reading on the gauge normal motor
poolboy
Not necessarily. What you did was like trying to take a persons temperature with a stethoscope.
What you did not test was compression.
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
sundown TR6 1973 tr6 oil pressure light Triumph 3
M TR6 1973 TR6 - broken choke cable Triumph 6
M TR6 1973 TR6 Coolant Type? Triumph 5
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
sundown TR6 1973 tr6 Triumph 0
sundown TR6 1973 TR6 flasher unit Triumph 1
sundown TR6 1973 tr6 wiring Triumph 21
jerrybny TR6 1973 TR6 Seat Covers Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
JoeC TR6 1973 TR6 parts car Triumph 2
jerrybny TR6 1973 TR6 Front License Plate Bracket Triumph 1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
S Stag 1973 Triumph Stag Triumph 2
R TR6 1973 Final drive issues Triumph 5
