TR6 1973 Final drive issues
Ribbs
I dropped my final drive with the original intent of replacing the three stub axle and pinion oil seals but now I only seem to have succeeded in opening a can of worms. On the pinion oil seal, I thought I could follow the two simple steps outlined in the Bentley manual (51.20.01) of 'fit a new oil seal' and 'refit the drive flange'. But after the fact I see in the Moss Motors catalog where there were two types of pinion spacers used; a collapsible one and a solid one, used with shims, and that if you have the collapsible one and you loosen the pinion flange nut (which I have, to get to the seal) you're basically screwed, and will need to replace the ring/pinion with a solid spacer compatible type. That is definitely out of my comfort zone! Can I even tell which style spacer I have without removing the differential from the casing?
Second issue I'm running into on the stub axle seals; Once the stub axles were out of the housing, I had my local machine shop press off the bearings, so I could get the oil seals out. What I noticed on the right hand stub axle was some serious grinding on the shaft - I assume where the bearing sits (see picture). So I'm guessing that a previous bearing failed and caused the damage. So wouldn't they have had to move the replacement bearing outboard to avoid this area? And what is the proper location of the bearing on the shaft anyway? Also, various drawings of the stub axle show a raised shoulder that must be used to locate either the bearing or drive flange up against, but I see no sign of my stub axles having this feature.
philstr6
are the flanges still attached to the shaft,are both shafts this way grounded,it looks to me they ground the ridge thats a stop for the bearing not to go any further
the machine shop should take the flange off first,then you can get to your seal,and then you tap the bearing off,reverse the process putting it back together
Phil
R
Ribbs
Yes, flanges are still attached to the shaft. The right hand shaft is the only shaft ground down. However, the left hand shaft has no shoulder/ridge either and no sign that it ever had one, which makes me think that the ground down area on the right hand stub axle pictured is damage from a failed bearing, but how is anything located then (flange and bearing)? Also, there was nothing to prevent the bearings from coming off in the direction of the splines (opposite of the flanges).
poolboy
The type of pinion shaft nut should provide a clue as the whether you have a solid or collapsible spacer.
Is yours a large 'Nyloc' or a large Castellated nut with a cotter pin ?
R
Ribbs
Oh crap Ken, I should have thought of that. I have a castellated nut - so I guess that means I have the collapsible? In which case I'm in over my head.
poolboy
Not according to mine...castellated nut and a solid, non-colapsible spacer.
To me, this subject is one where the Haynes (Chapter 8 Rear Axle) is better than the Bentley....
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
S Stag 1973 Triumph Stag Triumph 2
M TR6 1973 TR6 - broken choke cable Triumph 6
M TR6 1973 TR6 Coolant Type? Triumph 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
K 1973 MGB for sale MG Classifieds 0
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
J MGB 1973 MGB Value MG 8
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
E TR6 1973 TR-6 Unbalanced Intake Triumph 11
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
Boink 1973 Marcos MINI Spotted 1
J 1973 2500M ignition issue TVR 8
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 TR window regulator Triumph 2
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
