Patrolicious - 1973 Land Rover Series III
Nunyas
Looks like such a fun vehicle to have to tool around town or get out into the wilderness with
PAUL161
I bought one new in 73 and hated it! Had it one year and sold it. During that time, the brakes had to be worked on, one seat broke down, and three rear axles later is when I sold it. It's a 55 MPH vehicle and at that the engine is screaming. A doctor friend I know had the longer version that he took to Africa every year on safari. He had a special axle carrier made that bolted to the inter rear wheel wells to carry 4 spare axles. Last axle I bought was $185.00! Last time I saw his it was in the shop getting a new right door that a Rhino put his horn through, plus other work. Mine was never abused and the broken axles was taking off at an intersection where sand was on the asphalt and the tires slipped when taking off until they hit dry pavement and snapped the axles. They are unique though in the fact they have full floating rears and front spindles. If you break an axle, (more than likely will), you just put it in 4 wheel drive and keep going. I was very happy to sell the one I had.
I forgot to ad, I bought a 6 cyl Jeep CJ to replace it and loved it! Had the Jeep for 12 years. PJ
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
S Stag 1973 Triumph Stag Triumph 2
M TR6 1973 TR6 - broken choke cable Triumph 6
M TR6 1973 TR6 Coolant Type? Triumph 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R TR6 1973 Final drive issues Triumph 5
K 1973 MGB for sale MG Classifieds 0
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
J MGB 1973 MGB Value MG 8
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
E TR6 1973 TR-6 Unbalanced Intake Triumph 11
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
Boink 1973 Marcos MINI Spotted 1
J 1973 2500M ignition issue TVR 8
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 TR window regulator Triumph 2
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
