GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no?
2wrench
Could a '73 GT6 MK3 engine work in my '74 TR6?
Am I drawing at straws now? Don't want to act
stupid, but had a guy get me a little excited at
putting in a good running engine to tide me over
while I sink some dollars a little more over time
into a nice '74 engine replacement.
Just not familiar enough with these cars to know.
swift6
It will rev much more easily and higher, be slightly smoother, but it will lack the torque necessary for the proper TR6 experience.
Andrew Mace
Re: 1973 Triumph GT6 MK3 Engine for a TR6, yes or
Also, comparing "stock" motors, horsepower is down significantly: 79hp for a stock late Mk3 GT6 engine v. 105 or so for the TR6.
I've had both a GT6+ and later GT6 Mk3 (both stock). While the latter car wasn't exactly slow, it was noticeably less quick than the GT6+.
G
Now, my buddy wedged an "improved" GT6 engine into his TR3. Woof, that is an experience to drive!
rotoflex
The TR6 is heavier than the GT6, & really needs the torque from the extra displacement to make it seem like a car with go.
I love the GT6 engine, like it better than the 2.5 litre TR6 engine, but in the TR6 neither the engine, car, or driver would be having a real good time.
TR6 engine goes in TR6. Different engine, different car, different requirements, different power output, different operational characteristics, different feel.
TR6oldtimer
If it is available, cheap, and will get you on the road, and the reduction in performance is acceptable while you build up a TR6 engine, then what ever works for you seems the thing to do.
TR6oldtimer
racingenglishcars said:
It would feel like driving an Opel sedan
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif But it would be on the road....
Mickey Richaud
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif And he DID say that it was just to tide him over while he builds up a "proper" TR6 engine.
GO FOR IT!
G
Of course you could put a TR6 head on it then make up for the lack of low end torque by supercharging it. You'd get a 2.0L that'll rev to 7.5k and scream all the way.
Cost would be way less than a rebuilt engine from TRF...
/bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
T GT6 1973 Triumph GT6 MK3 for Sale - $3000 Triumph 17
S Stag 1973 Triumph Stag Triumph 2
TR6oldtimer 1973 Triumph Training Notes, emissions and carb Triumph 2
StagByTriumph Stag 1973 Triumph Stag on eBay Triumph 0
StagByTriumph Stag 1973 Triumph Stag on eBay Triumph 16
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
M TR6 1973 TR6 - broken choke cable Triumph 6
M TR6 1973 TR6 Coolant Type? Triumph 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R TR6 1973 Final drive issues Triumph 5
K 1973 MGB for sale MG Classifieds 0
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
J MGB 1973 MGB Value MG 8
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
E TR6 1973 TR-6 Unbalanced Intake Triumph 11
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
Boink 1973 Marcos MINI Spotted 1
J 1973 2500M ignition issue TVR 8
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
Nunyas Patrolicious - 1973 Land Rover Series III Other Cars 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
