    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR6 TR6 FUEL TANK VENT PIPE
machinemd
I'VE GOT ANOTHER QUESTION FOR THE EXPERIENCED MINDS. I FOUND LAST YEAR THAT MY "NEW TO ME" 1974 TR6 FUEL TANK VENT PIPE JUST ENDED WHERE THE CHARCOAL CANISTER USED TO BE. WELL, I FOUND WHERE THE OCCASIONAL GAS FUMES WERE COMING FROM. NOW WHAT DO I DO ABOUT IT? WHAT'S EVERYBODY ELSE DO WHEN THE EMISSION HARDWARE IS LONG GONE?
THANKS, STEVE
I would think another unit out of a more modern car in a salvage yard would suffice, they are all black plastic and similar in size and function.(pricy when new though)
MD(mad dog)
The only pollution parts left are this vent pipe and the EGR valve, and I don't even know if it's operable. I remember reading this issue on one of the lists a while back. One guy rerouted it to end near the bottom of the passenger rear quarter panel, away from the exhaust, and stuck either a fuel filter or pcv valve at the end of it. Another capped it at the tank and somehow drilled a small vent hole in the filler cap. Or can it be tied in to any of the many capped nipples that I have? Open to ideas!
The original routing had the tank vent going through the carbon canister which then tied into the emmission pipes from the valve cover to the carbs and everything was burned in the engine. This was to create a sealed system so the gas vapors did not vent to the atmosphere. Unlike the EGR valve, this did not create a hp loss, or, so I am told.
I assume the emmission pipes still run from the valve cover to the carbs. If not, how is the crankcase breathing (relieving the builtup internal pressures)?
The carbon canisters are still available new for around $100 and a used one that requires service can be had for about $50. Personally, I like the sealed system method as I know where the fuel tank is venting.
G TR6 TR6 fuel tank fitting size. Triumph 14
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
B TR6 71 TR6 Fuel Tank firewall? Triumph 6
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
F TR6 TR6 Fuel Pump Priming Triumph 11
sundown TR6 1973 TR6 fuel pump Triumph 4
B TR6 TR6 Fuel Filter keeps clogging Triumph 9
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
D TR6 1976 TR6 Fuel Lines Triumph 7
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
Gliderman8 TR6 Troubleshoot a TR6 Fuel gauge problem Triumph 36
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
M TR6 TR6 Fuel Delivery Issue Triumph 18
I TR6 TR6 fuel pipe nut source? Triumph 5
I TR6 TR6 fuel pump - how do I replace these? Triumph 18
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
T TR6 tr6 fuel sending unit Triumph 5
G TR6 TR6 Fuel Injection ? Triumph 8
BobbyD TR6 TR6 Fuel Pump Triumph 1
Brosky TR6 Fuel Pump Kit for TR6 Triumph 3
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
DNK TR6 TR6 fuel lines. Triumph 20
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
J TR6 Just another whining TR6 fuel pump again? Triumph 19
SCguy TR6 How can you tell if your TR6 fuel pump is working? Triumph 4
I TR6 TR6 Fuel gauge help Triumph 7
E TR6 TR6 Fuel / Mixture ? Triumph 4
71tr TR6 fuel line TR6 Triumph 2
V TR6 Oil and Fuel for TR6 Triumph 6
I TR6 Fuel injection for TR6 Triumph 4
G TR6 Free OE TR6 Fuel Pump.....................8 bucks. Triumph 2
71tr TR6 fuel line TR6 Triumph 6
V TR6 TR6 Fuel pump spares Triumph 8
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
I TR6 fuel lines for 69 TR6 Triumph 3
Tullamore TR6 TR6 Fuel Leak Triumph 4
Morris TR6 TR6 Fuel Injection Triumph 21
padjo TR6 TR6 Fuel Pump Triumph 1
tr6web TR6 TR6 Manifold gasket help Triumph 1
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
