TR6 fuel line TR6
71tr
Quick question; anyone know what size the fuel line is in a '71 TR6?
cyaker
I just replaced all mine on a 73. 5/16" tubing matched up with the old ones. I picked up a 25' roll at AutoZone for main line and return. Ended up with about 6-8 feet left over.
71tr
71tr
cyaker
thanks a lot, that is what i thought the size to be. by the way, how did you go about straightening the rolled line?
G
5/16" is correct size. You can pick up random lengths of rigid steel fuel line from your local NAPA dealer as well. Rigid line is a bit tougher to bend but there aren't that many complicated bends beneath your car.
Bill
G
Also, make sure you use quality rubber fuel line for the few junctions that require rubber. I always use geniune Gates rubber fuel line material.
Bill
cyaker
Getting it straight from the coil was pretty easy. I used a 'loan-a-tool' tubing bender from Advance Auto. It was not great on the tigher turns, but they none of the turns are very tight. I had saved my old lines to provide a pretty good guide for the initial cuts and bends.
philknight
Check out www.classictube.com, They have prebent lines in steel or stainless. I couldn't bend lines to my satisfaction so that's the route I went. The fit and finish was excellent, though it did take them quite a while to ship. It did not include the final piece that splits to the carbs. If you go to their site you have to hit search -triumph - all models - all years to find the fuel lines. If you get model specific it only shows hydraulic lines.
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
71tr TR6 fuel line TR6 Triumph 2
A TR2/3/3A Those round fuel line clips Triumph 2
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
G TR6 Clogged fuel line Triumph 6
petnatcar Fuel Line Upgrade Austin Healey 8
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
D TR2/3/3A rearmost fuel line question Triumph 5
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
steveg TR6 Source for fuel line P-clip Triumph 17
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Bayless What size fuel line for '67 Sprite? Spridgets 2
dklawson General TR Fuel Line Routing Triumph 4
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
D 62 tri-carb fuel line connection Austin Healey 10
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
D TR2/3/3A tr3 fuel line Triumph 9
S General Tech fuel line vents in general Triumph 4
R BJ7 end couplings for fuel line Austin Healey 7
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
G TR4/4A Using existing fuel line Triumph 5
G Wanted TR4/4A[?] Stay Rods and Fuel Line Triumph Classifieds 1
C TR2/3/3A Flexible fuel line Triumph 2
V TR2/3/3A Fuel Line into Fuel Pump Triumph 5
C TR4/4A Fuel line question..... Triumph 3
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
M Fuel Line Assistance Needed Spridgets 5
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
J TR4/4A Fuel line Triumph 2
petnatcar FUEL LINE CONVERSION for BT7 Austin Healey 1
DornTRoriginal TR2/3/3A Gas Line/Fuel Pipe Installation Questions Triumph 2
M BN1 carburetor fuel line Austin Healey 9
V TR2/3/3A TR-3B Fuel Line Question Triumph 7
E TR4/4A TR$ Fuel line from tank Triumph 13
H TR5/TR250 Fuel line route Triumph 3
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
T TR2/3/3A Fuel line heat shield Triumph 39
M_Pied_Lourd TR4/4A TR4 fuel line run. Triumph 5
P TR6 Fuel line and Foley catheter blockage Triumph 5
K TR2/3/3A Copper fuel line..... Triumph 6
M TR4/4A Exhaust/ Fuel line? Triumph 8
