Fuel Line Assistance Needed
mxp01
All:
I have a 59 BE with a mechanical fuel pump. The car has a replica metal fuel line, just like the original BE line. However, the ends of the fuel line, where they connect to the fuel tank and fuel pump, do not have fittings nor are the ends flared (like brake lines). Moss sold a compression sleeve and tube nut (P/N 376-565 and 376-575) that would do the trick, but do not have available the "tube nut" (P/N 376-575). I have a feeling that these tube nuts are fairly standard, but would love some advice on what to purchase.
If you have any ideas, please let me know.
Mike Pennell
I think your local hardware store can fix you up. That is if you still have a good one.
Kurt
I think AH Spares has it also. I bought my fuel line from AH Spares and it came complete. couldn't be happier!
Thanks, guys. I went to a few stores today without luck. I did find the parts through VB, but they take a long time to ship or the charge stiff premium for overnight delivery. I'm returning to work on Monday, so was hoping to get this done today. BTW: I spoke with MOSS on the phone and while their online ordering system say they don't have the part, the guy on the phone said they do have them in stock.
A good hardware store? Do they exist anymore?
Yeah, I know what you mean. We have a nearly new ACE that was extremely well stocked but as it ages the boxes are emptying and not getting refilled! I would thing common compression fittings would do the trick.
Kurt.
A TR2/3/3A Those round fuel line clips Triumph 2
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
G TR6 Clogged fuel line Triumph 6
petnatcar Fuel Line Upgrade Austin Healey 8
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
D TR2/3/3A rearmost fuel line question Triumph 5
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
steveg TR6 Source for fuel line P-clip Triumph 17
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Bayless What size fuel line for '67 Sprite? Spridgets 2
dklawson General TR Fuel Line Routing Triumph 4
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
D 62 tri-carb fuel line connection Austin Healey 10
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
D TR2/3/3A tr3 fuel line Triumph 9
S General Tech fuel line vents in general Triumph 4
R BJ7 end couplings for fuel line Austin Healey 7
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
G TR4/4A Using existing fuel line Triumph 5
G Wanted TR4/4A[?] Stay Rods and Fuel Line Triumph Classifieds 1
C TR2/3/3A Flexible fuel line Triumph 2
V TR2/3/3A Fuel Line into Fuel Pump Triumph 5
C TR4/4A Fuel line question..... Triumph 3
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
J TR4/4A Fuel line Triumph 2
petnatcar FUEL LINE CONVERSION for BT7 Austin Healey 1
DornTRoriginal TR2/3/3A Gas Line/Fuel Pipe Installation Questions Triumph 2
M BN1 carburetor fuel line Austin Healey 9
V TR2/3/3A TR-3B Fuel Line Question Triumph 7
E TR4/4A TR$ Fuel line from tank Triumph 13
H TR5/TR250 Fuel line route Triumph 3
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
T TR2/3/3A Fuel line heat shield Triumph 39
M_Pied_Lourd TR4/4A TR4 fuel line run. Triumph 5
P TR6 Fuel line and Foley catheter blockage Triumph 5
K TR2/3/3A Copper fuel line..... Triumph 6
M TR4/4A Exhaust/ Fuel line? Triumph 8
J 1/4" BSPP Fuel Line Connection, Hose from Steel Line to Carb Austin Healey 2
J Fitting 5/16" Steel to 5/16" Braided SS Rubber Fuel Line Austin Healey 4
AHS TR2/3/3A Fuel line to tank routing? Triumph 2
