    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR6 fuel line TR6
71tr
anyone know what size fuel line is used in the TR6?
5/16, 1/4 perhaps?
Larry,
Thanks, I thought there was a difference. I had purchased some 5/16 line and when I compared to the pump-carb line was surprised that I had 'screwed up'. This explains everything.
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
71tr TR6 fuel line TR6 Triumph 6
A TR2/3/3A Those round fuel line clips Triumph 2
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
G TR6 Clogged fuel line Triumph 6
petnatcar Fuel Line Upgrade Austin Healey 8
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
D TR2/3/3A rearmost fuel line question Triumph 5
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
steveg TR6 Source for fuel line P-clip Triumph 17
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Bayless What size fuel line for '67 Sprite? Spridgets 2
dklawson General TR Fuel Line Routing Triumph 4
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
D 62 tri-carb fuel line connection Austin Healey 10
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
D TR2/3/3A tr3 fuel line Triumph 9
S General Tech fuel line vents in general Triumph 4
R BJ7 end couplings for fuel line Austin Healey 7
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
G TR4/4A Using existing fuel line Triumph 5
G Wanted TR4/4A[?] Stay Rods and Fuel Line Triumph Classifieds 1
C TR2/3/3A Flexible fuel line Triumph 2
V TR2/3/3A Fuel Line into Fuel Pump Triumph 5
C TR4/4A Fuel line question..... Triumph 3
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
M Fuel Line Assistance Needed Spridgets 5
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
J TR4/4A Fuel line Triumph 2
petnatcar FUEL LINE CONVERSION for BT7 Austin Healey 1
DornTRoriginal TR2/3/3A Gas Line/Fuel Pipe Installation Questions Triumph 2
M BN1 carburetor fuel line Austin Healey 9
V TR2/3/3A TR-3B Fuel Line Question Triumph 7
E TR4/4A TR$ Fuel line from tank Triumph 13
H TR5/TR250 Fuel line route Triumph 3
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
T TR2/3/3A Fuel line heat shield Triumph 39
M_Pied_Lourd TR4/4A TR4 fuel line run. Triumph 5
P TR6 Fuel line and Foley catheter blockage Triumph 5
K TR2/3/3A Copper fuel line..... Triumph 6
M TR4/4A Exhaust/ Fuel line? Triumph 8
