TR6 1976 TR6 Fuel Lines
Don_Houston
The original return line from the Separation tank to the Carbon Canister is generally metal up to about the engine block. From there to the Carbon Canister it is some kind of plastic line. The plastic line snapped while I was replacing the steel line. What would be the best replacement for the plastic line - metal / rubber fuel line?
Also, It does not look like replacement Separation Tanks (back by the gas tank) are available. I don't know if I need one, but how do I check my current one? (the car is generally in good shape with 23k miles, but has not been driven in 30 years)
I will be getting into the brakes soon. Should I keep the rear brakes as drum type or are most people converting them to disk?
Many Thanks!
poolboy
As far as I know nothing goes on in the separation canister except that gas vapors have a chance to condense. No moving parts to wear out. You can blow compressed air thru it to make sure nothing is clogging up the inlet and outlet
If you look aound locally I bet you can find the original type nylon emission tubing.
I would say that very very few people find the need or the money to convert the rear brakes to disc..
TR3driver
Great Pumpkin - R.I.P
:iagree:
One source for the tubing might be MMC . Up to you to find the right material and size, though.
Rear discs are mostly for bragging rights. Even with discs up front, the front brakes will overheat before the rears do. A more common conversion (tho still mostly for bling IMO) is aluminum drums to reduce unsprung weight.
TR3driver
The hard line, or the 'nylon' ?
A quick search at MMC turned up 74 selections in gasoline-compatible plastic tubing with 1/4" od. Oddly enough, only 36 in 1/4" id.
ISTR the same line on my Stag is closer to 5/16" od, but I could be mistaken (or the Stag could be different).
DNK
The nylon is OD.
Great if you have the time to have MMC ship it and want to pay their freight
Don_Houston
Thank to everyone for the input!
As part of my refurbishment, I pulled the radiator, had it checked for leaks (none) and had it completely cleaned, flushed and painted. Since it was a royal pain getting the bottom hose removed for the initial drain, I had my radiator guy install a pitcock / drain on the opposite side from the drain hose. I hope this was a good idea as I think it will make annual flushing much easier. What do you think?
TR3driver
Or if you live just down the road and can pick it up at the "will call" counter :smile:
Actually, my experience has been that they ship very promptly (usually the same business day) and the shipping charges are reasonable (on the occasions when I don't want to bother with driving over there). Unlike some other similar suppliers, they have no minimum order or surcharge on small orders. Their prices are not cheap (definitely not a discount supplier) but seem reasonable to me considering the huge selection of parts, tools and materials that they keep in stock at every district warehouse.
And their on-line catalog is simply great, with links to material information, CAD drawings, MSDS, etc for practically everything I'm interested in. Want to know if 4140 is easier to weld than 12L14? How about the coefficient of thermal expansion for Delrin? It's in there ...
Don_Houston, the drain valve sounds like a good idea to me. I would have added one if my car didn't already have it.
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
B TR6 TR6 1976 Clutch Choice Question Triumph 3
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
TR6BobNF For Sale 1976 TR6 Engine Triumph Classifieds 1
D TR6 1976 TR6 - Can Rubber Guards be Removed from Bumpers? Triumph 9
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
D TR6 1976 TR6 Black Painted Parts Triumph 2
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
D TR6 1976 TR6 Seats Triumph 4
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
D TR6 1976 TR6 Clutch & Brakes Triumph 5
D TR6 1976 TR6 Brakes and Clutch Triumph 0
D TR6 1976 TR6 Rebuild Triumph 11
M TR6 1976 TR6 Ignition problem Triumph 6
S TR6 Paint in a 1976 TR6 Triumph 8
T TR6 Tire Preservation Question - 1976 TR6 Triumph 13
T TR6 1976 Triumph TR6 For Sale in Classified Section Triumph 0
BillyZ TR6 1976 TR6 Ignition warning light Triumph 17
P TR6 1976 tr6 specs Triumph 3
B TR6 1976 TR6 For Sale Triumph 2
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
DrEntropy A couple Cumberland SCCA Runoff shots, 1976 Racing 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
S For Sale MG MGB Factory Parts Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale MG MGB Factory Workshop Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
A Wondering about buying a 1976 mg midget will it smog? Spridgets 8
E New London Taxi Owner 1976 FX4 Other British Cars 1
B For Sale 1976 MG midget MG Classifieds 0
RickB MGB 1976 MGB with OD and factory hardtop - one owner MG 4
R MGB 1976 MGB for sale MG 0
K 1976 BMW 530i Other Cars 3
DrEntropy MGB 1976 MGB Roadster for a patient. MG 2
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
D Spitfire 1976 spitfire rear bumper question Triumph 3
ArcticOne Spitfire 1976 Spit in Southern Alberta Triumph 0
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
R MGB 1976 MGB restoration question MG 11
bighly 1976 Midget Motor mount brackets needed Spridgets 0
M 1976 still won't start Spridgets 4
L MGB 1976 MGB - $500 [Santa Clarita] MG 1
J TR6 Need front bumper for 1976 TR 6 Triumph 6
J MGB 1976 mgb backfire MG 5
AngliaGT 1976 Triumph T140 Article in 11/07 Cycle World British Motorbikes 5
AngliaGT 1976 Bonneville - Anyone Interested? British Motorbikes 0
Bret 1976' Porsche 911 Targa Slantnose - Real or Not? Other Cars 14
E Wedge 1976 TR7 Victory Edition on eBay Triumph 5
