TR6 1976 TR6 Gas smell in Trunk
DonM
Hi Folks! Is it common to have a gas smell in the trunk? When I refurbished the gas tank I pulled it out and had it professional blasted and coated so I don't think the tank itself is the issue. There are four connections - filler tube, gas gauge, vapor recovery, and the discharge line up to the engine.
Anyone with a similar experience? Many Thanks!
poolboy
Was the mat under the tank, changed or replaced ?...The original mat was 'felt' (Moss #763-040) and was good at retaining the odor of gas if there was ever a leak or a spill from over filling.
A closed cell foam is more practical.
DonM
Does this mean you disabled the vent line? And if so, is there any downside to doing this? Many thanks!
jimstr4
There might be a downside to blocking off the vent pipe if the gases build up but I'd assume that our tanks don't really seal 100% anyway.
Might not be safe I suppose.
My car sat in my mother's garage which is part of her house, her house had a bit of a smell of petrol at times.
So I repaired the leaking fuel pump and used petrol resistant tape on the inlet and outlet, removed the tank and had the outlet repaired (2nd time the tank's been repaired).
It still smelled of petrol so I blocked off the vent pipe and no more discernible smell.
I overhauled my carbies years ago as they leaked but need to do that again as they have started to leak a bit again or I can replace them with injectors.
poolboy
Generally, you'll need some where for air to get in so the gasoline can get out...otherwise a vacuum will be created as the fuel level drops, then the flow of gas stops.
DonM
Thanks for all of the input. I later found that there are some old threads on this subject as well, which are helpful, Apparently, a very common problem.
My main target is the fuel gauge which I replaced a few years ago when I completely refurbished the tank. I recall the screws did not want to seat completely and I didn't want to force them.
The vent line is new and appears to be properly clamped but if the carbon filter has a problem it might cause the vent line not to work properly? Can the carbon canister be cleaned or just buy a new one ($67 form Moss)?
I'll report back on progress! Many thanks!
Gliderman8
The carbon canister comes apart and can be cleaned. I believe that you may be able to get carbon granules from a place that sells aquarium supplies. With that said, I just disconnected mine.
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
B TR6 TR6 1976 Clutch Choice Question Triumph 3
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
TR6BobNF For Sale 1976 TR6 Engine Triumph Classifieds 1
D TR6 1976 TR6 - Can Rubber Guards be Removed from Bumpers? Triumph 9
D TR6 1976 TR6 Black Painted Parts Triumph 2
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
D TR6 1976 TR6 Seats Triumph 4
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
D TR6 1976 TR6 Clutch & Brakes Triumph 5
D TR6 1976 TR6 Brakes and Clutch Triumph 0
D TR6 1976 TR6 Fuel Lines Triumph 7
D TR6 1976 TR6 Rebuild Triumph 11
M TR6 1976 TR6 Ignition problem Triumph 6
S TR6 Paint in a 1976 TR6 Triumph 8
T TR6 Tire Preservation Question - 1976 TR6 Triumph 13
T TR6 1976 Triumph TR6 For Sale in Classified Section Triumph 0
BillyZ TR6 1976 TR6 Ignition warning light Triumph 17
P TR6 1976 tr6 specs Triumph 3
B TR6 1976 TR6 For Sale Triumph 2
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
DrEntropy A couple Cumberland SCCA Runoff shots, 1976 Racing 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
S For Sale MG MGB Factory Parts Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale MG MGB Factory Workshop Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
A Wondering about buying a 1976 mg midget will it smog? Spridgets 8
E New London Taxi Owner 1976 FX4 Other British Cars 1
B For Sale 1976 MG midget MG Classifieds 0
RickB MGB 1976 MGB with OD and factory hardtop - one owner MG 4
R MGB 1976 MGB for sale MG 0
K 1976 BMW 530i Other Cars 3
DrEntropy MGB 1976 MGB Roadster for a patient. MG 2
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
D Spitfire 1976 spitfire rear bumper question Triumph 3
ArcticOne Spitfire 1976 Spit in Southern Alberta Triumph 0
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
R MGB 1976 MGB restoration question MG 11
bighly 1976 Midget Motor mount brackets needed Spridgets 0
M 1976 still won't start Spridgets 4
L MGB 1976 MGB - $500 [Santa Clarita] MG 1
J TR6 Need front bumper for 1976 TR 6 Triumph 6
J MGB 1976 mgb backfire MG 5
AngliaGT 1976 Triumph T140 Article in 11/07 Cycle World British Motorbikes 5
AngliaGT 1976 Bonneville - Anyone Interested? British Motorbikes 0
Bret 1976' Porsche 911 Targa Slantnose - Real or Not? Other Cars 14
E Wedge 1976 TR7 Victory Edition on eBay Triumph 5
