TR6 1976 TR6 Ignition problem
Marty_Dooley
Hello,
I need your help.
Two weeks ago we were driving along and all was fine - until the engine died and would not restart.
We are getting spark out of coil to the distributor.
We have the replaced coil, the condenser, and swapped out the distributor cap and the points are opening and closing.
But - no spark to the plugs.
Does anyone have any suggestions.....
Thanks and best regards,
Marty Dooley
TR3driver
Great Pumpkin - R.I.P
Still sounds like a bum rotor to me :smile:
poolboy
Do you see a spark jumping across the points as they open ?
There's a ground wire inside the distributor. You should see it when you remove the distributor cap. One end of it is screwed onto the rim of the distributor. Is it intact ?
Then there's the rotor; did you replace it even though it might look OK ?
G
quote]
Marty_Dooley said:
Hello,
Yeah, exactly where are you talking about? Primary or secondary voltage?
If you haven't serviced your ignition in a while, do: points, condenser, cap, rotor, plugs, wires. You'll be happy you did. Sounds like just the rotor or coil wire, but I'd do it all.
M
Marty_Dooley
Yes, we did have spark across the points, and the rotor looked fine. However, when we replaced the rotor - she started immediately. I still don't understand how such a simple mechanical part that appears undamaged could cause such grief.
Anyway, Gentlemen, thank for all you help.
Best regards,
Marty Dooley
DNK
A lot of bad rotors at all the locations.
Best thing,buy a couple from Jeff. There is someone else selling the similar thing claiming they are his. They are red too.
TR3driver
It's an electrical part; the body of the rotor has to keep full spark voltage from jumping through it to the grounded center post. Sometimes, it doesn't make it. Once the spark starts to jump through the rotor even occasionally, it will quickly leave a carbon path that conducts enough to short out the high voltage, but is completely invisible since it's inside the body of the rotor.
I would also be looking for a bad plug wire. Sometimes when a wire starts to fail, it lets the voltage rise higher than usual before the plug fires. Last time I saw a rotor fail, there was also a broken resistor inside one plug wire.
BillyZ TR6 1976 TR6 Ignition warning light Triumph 17
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
B TR6 TR6 1976 Clutch Choice Question Triumph 3
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
TR6BobNF For Sale 1976 TR6 Engine Triumph Classifieds 1
D TR6 1976 TR6 - Can Rubber Guards be Removed from Bumpers? Triumph 9
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
D TR6 1976 TR6 Black Painted Parts Triumph 2
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
D TR6 1976 TR6 Seats Triumph 4
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
D TR6 1976 TR6 Clutch & Brakes Triumph 5
D TR6 1976 TR6 Brakes and Clutch Triumph 0
D TR6 1976 TR6 Fuel Lines Triumph 7
D TR6 1976 TR6 Rebuild Triumph 11
S TR6 Paint in a 1976 TR6 Triumph 8
T TR6 Tire Preservation Question - 1976 TR6 Triumph 13
T TR6 1976 Triumph TR6 For Sale in Classified Section Triumph 0
P TR6 1976 tr6 specs Triumph 3
B TR6 1976 TR6 For Sale Triumph 2
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
DrEntropy A couple Cumberland SCCA Runoff shots, 1976 Racing 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
S For Sale MG MGB Factory Parts Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale MG MGB Factory Workshop Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
A Wondering about buying a 1976 mg midget will it smog? Spridgets 8
E New London Taxi Owner 1976 FX4 Other British Cars 1
B For Sale 1976 MG midget MG Classifieds 0
RickB MGB 1976 MGB with OD and factory hardtop - one owner MG 4
R MGB 1976 MGB for sale MG 0
K 1976 BMW 530i Other Cars 3
DrEntropy MGB 1976 MGB Roadster for a patient. MG 2
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
D Spitfire 1976 spitfire rear bumper question Triumph 3
ArcticOne Spitfire 1976 Spit in Southern Alberta Triumph 0
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
R MGB 1976 MGB restoration question MG 11
bighly 1976 Midget Motor mount brackets needed Spridgets 0
M 1976 still won't start Spridgets 4
L MGB 1976 MGB - $500 [Santa Clarita] MG 1
J TR6 Need front bumper for 1976 TR 6 Triumph 6
J MGB 1976 mgb backfire MG 5
AngliaGT 1976 Triumph T140 Article in 11/07 Cycle World British Motorbikes 5
AngliaGT 1976 Bonneville - Anyone Interested? British Motorbikes 0
Bret 1976' Porsche 911 Targa Slantnose - Real or Not? Other Cars 14
E Wedge 1976 TR7 Victory Edition on eBay Triumph 5
