TR6 1976 TR6 Front Brakes & Shocks
Don_Houston
I removed the 30 year old front brakes yesterday, what fun! I have researched new brakes on Moss, VB and TRF and its confusing. Moss sells the front kit for $750 and say that they are "upgraded" brakes and they don't stock their "regular" set anyway which would be about $550. VB's "regular" set looks to be at least $700 and TRF is difficult to navigate.
This is a big purchase, so what are my best options? I am not necessarily opposed to "upgraded" but don't want to do a bunch of modifications that may be beyond my skill (this is my first brake job).
It looks like I should replace the shocks while I'm in there as they look pretty cruddy (I already have the parts to refurbish the suspension bushings). What are the best shocks to install?
Many thanks.
70herald
Unless there is something seriously broken with the brakes, there is no need to replace them, what you need are new hoses, rebuild kit for the front brakes which will have o-rings and dust seals, probably new pistons. In the back just get new cylinders. Take apart the master cylinder and see if it is corroded inside, if so you can either have a sleeve put in or get a new one. All of this should be WAY less than $700.
You will also need new brake pads and shoes, here you get what you pay for and there are differences in quality. Probably the best thing to do is contact TSI ?? and see what they recommend relining with.
Finally, you need to take the disks and drums to a local brake shop for them to check if they are round / warped / thick enough / and turn them (if possible) otherwise you will need new bits here also.
And one more thing, check over the 30 year old brake pipes also for any signs of damage.
GerryL
The only thing that you may also do is replace the steel lines with a copper nichol brake line kit. These lines come with all the necessary fittings and the lines can be hand bent. You may want to consider replacing the flexible lines with those enclosed by stainless steel. When you replace the caliper pistons you would want to either use chrome or nitrated ones. You may want to consider using silicone fluid.
mrv8q
I'm with 70Herald... Unless your brake booster is shot... Brougnt my '74 back with new pistons and hoses and pads; brakes were surprisingly good!
FWIW, TRF is having a "brake sale".
https://trf.zeni.net/wc/specials7.27/
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
B TR6 TR6 1976 Clutch Choice Question Triumph 3
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
TR6BobNF For Sale 1976 TR6 Engine Triumph Classifieds 1
D TR6 1976 TR6 - Can Rubber Guards be Removed from Bumpers? Triumph 9
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
D TR6 1976 TR6 Black Painted Parts Triumph 2
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
D TR6 1976 TR6 Seats Triumph 4
D TR6 1976 TR6 Clutch & Brakes Triumph 5
D TR6 1976 TR6 Brakes and Clutch Triumph 0
D TR6 1976 TR6 Fuel Lines Triumph 7
D TR6 1976 TR6 Rebuild Triumph 11
M TR6 1976 TR6 Ignition problem Triumph 6
S TR6 Paint in a 1976 TR6 Triumph 8
T TR6 Tire Preservation Question - 1976 TR6 Triumph 13
T TR6 1976 Triumph TR6 For Sale in Classified Section Triumph 0
BillyZ TR6 1976 TR6 Ignition warning light Triumph 17
P TR6 1976 tr6 specs Triumph 3
B TR6 1976 TR6 For Sale Triumph 2
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
DrEntropy A couple Cumberland SCCA Runoff shots, 1976 Racing 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
S For Sale MG MGB Factory Parts Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale MG MGB Factory Workshop Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
A Wondering about buying a 1976 mg midget will it smog? Spridgets 8
E New London Taxi Owner 1976 FX4 Other British Cars 1
B For Sale 1976 MG midget MG Classifieds 0
RickB MGB 1976 MGB with OD and factory hardtop - one owner MG 4
R MGB 1976 MGB for sale MG 0
K 1976 BMW 530i Other Cars 3
DrEntropy MGB 1976 MGB Roadster for a patient. MG 2
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
D Spitfire 1976 spitfire rear bumper question Triumph 3
ArcticOne Spitfire 1976 Spit in Southern Alberta Triumph 0
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
R MGB 1976 MGB restoration question MG 11
bighly 1976 Midget Motor mount brackets needed Spridgets 0
M 1976 still won't start Spridgets 4
L MGB 1976 MGB - $500 [Santa Clarita] MG 1
J TR6 Need front bumper for 1976 TR 6 Triumph 6
J MGB 1976 mgb backfire MG 5
AngliaGT 1976 Triumph T140 Article in 11/07 Cycle World British Motorbikes 5
AngliaGT 1976 Bonneville - Anyone Interested? British Motorbikes 0
Bret 1976' Porsche 911 Targa Slantnose - Real or Not? Other Cars 14
E Wedge 1976 TR7 Victory Edition on eBay Triumph 5
