Fuel Pump Ticking but Not Pumping
Daniel Kaminsky
AH BJ8, fuel pump about an 8 yr. old replacement, appears to be from Moss. Worked fine until it stopped clicking. Removed and cleaned points, bench tested with gas and ran it for 30 minutes perfectly. Put back on car, disconnected fuel line by carbs to lower resistance, ticks continuously but will not pick up fuel. Took off fuel line filler cap, tried again. No luck. Suggestions?
BobHaskell
Outlet pipe is at the top of the pump, right? Could try pressurizing the fuel tank by blowing into the tank, sealing your mouth to the fill tube with your hand.
red57
Could be the fittings in the line from tank to pump are not sealing well causing a vacuum leak allowing air to be drawn in instead of fuel. It's possible to have a vacuum leak without leaking fuel at these fittings.
Daniel Kaminsky
It has been mentioned to put pressure in the tank. I was thinking of renting a small compressor, but maybe mouth pressure is enough? Also, the fitting is odd to me. The in/out lines attach just where the two large bolts pass through to secure them into the pump. It seems to me that they (the bolts) would block the flow of gas? Do all BJ8s have this setup? But I replaced it just as it was before, when the pump worked. Confusing. The upper line might not be seated just right. Will check it.
Likely inlet line air leak, like Red suggested. Be gentle, the pump bodies are soft ('pot?') metal and it's possible to cross-thread or strip them with the steel bolts. Did you mess with the diaphragm/body side of pump at all? Did you use new fiber washers (some pumps have O-rings)?
The fittings are called 'banjos,' for their shape; also found on carbs and oil feed line for the valve rocker. The bolts ('banjo bolts') are hollowed-out, and have a hole (or two?) through which fuel/oil passes. AFAIK, all 6-cyl cars used hard copper lines with banjos fitted; 4-cyl pumps used compression-type fittings with hard lines. Owners sometimes cut the hard lines and install flex lines to fit aftermarket pumps.
Michael Oritt
Or it could be a clogged fuel line anywhere between the tank pickup and the fitting to the pump.
BobHaskell
Bob,
Fuel lines are steel. Unions, some with right angle adapters, were used until the fuel pump (AUA 173 LCS) was moved to the right hand side of the car during 3000 MkII (BT7/BN7) production. Banjo fittings were then used to the end of BJ8 production.
If you have the Concours guidelines, there's a supplement written by Roger Moment covering the Big Healey pumps and change points. Originally published in Austin-Healey magazine (date not given in the guidelines).
BobHaskell
Bob, the banjo bolts are steel and have two side holes. The banjos are non-magnetic. I would guess that they're brass, but don't know.
Cutrog1 Fuel Pump Ticking Austin Healey 13
warwick-steve Ticking fuel pump Austin Healey 7
M Fuel Pump Ticking Austin Healey 7
AH67 facet fuel pump never stops ticking. Austin Healey 6
6 Solid State SU Fuel Pump Ticking: Constant? Austin Healey 4
B New fuel pump - loud ticking, now fuel spraying! Austin Healey 33
R TR2/3/3A Fuel pump? Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
