TR4/4A Fuel pump saga
jimstr4
I decided to post this so that others don't waste as much time as I have.
The pump was overhauled a bit over a year ago.
It had always leaked out the inlet pipe junction so I purchased a new pipe and olive (Furrule) from Rimmers about 3 months ago.
Installed it the recommended way by pushing the pipe in as far as it would go then tightened the nut.
No more leaks from the inlet.
A few weeks ago the car wouldn't start, I traced it to the fuel pump, replaced the 18month old diaphragm and put the pump back.
Tightened the inlet then the outlet, the 60 year old threads finally gave way on the outlet , stripped.
Removed the head then tried unsuccessfully to tap them.
Purchased a new pump and decided that since alot of people have had issues with them I'd use the new head on the old body.
I couldn't separate the head from the body until I shoved a knife between them, damaging the diaphragm, but that was ok as the old pump had a new one.
Screwed the new head onto the old body. lo and behold both pipes leaked.
Tried tightening up a bit more but didn't want to damage the soft metal, still leaked.
Went inside and had a lie down to destress.
Went out later and wrapped the olives in solvent resistant PTF tape, no leaks.
I'm going to replace the existing olives.
Someone up there is trying to send me a message as if it can go wrong it has......
Jim and the 1962 TR4
sail
^^^ That did it for me. I just used emory cloth to file down the olives so that two of them together are a bit larger than one.
J
jimstr4
Thank you for the replies. New Olives it is. The inlet pipe and olive were new a couple of months ago so I'll probably follow Randall's advice.
R TR2/3/3A Fuel pump? Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
sundown TR6 Fuel pump Triumph 10
