A Quiet SU Fuel Pump
vette
I don't know that I have experienced this before. I have two fuel pumps on my Healey. Since I bought them at different times and it has been awhile, my memory says that one is the points type and the other is a dual polarity electronic one. Anyway both have always given the traditional ticking sound when first starting the car. I usually switch from one to the other each time I take the car out, but recently the left one has stopped ticking.
At first, early this driving season, I noticed that it didn't tick as much. Many times when I first start the car for the day I would turn on one side and let it pump up then turn on the other side and let it pump up. This assured me that they were both working and that the system was fully charged. So the left one started to tick only a few times. I was concerned that it was failing, but I deliberately drove on that pump to verify that it was working or failing and I never ran out of gas. So the last few times out I would keep the circuit on that quiet pump to see if it would fail. It hasn't and I end up driving along for a good outing and never running out of gas, but It doesn't tick at all anymore.
Is that a little strange? I wonder why it is continuing to pump, but doesn't tick? Any thoughts?
roscoe
Re: A Quite SU Pump
I don't know if it is the same but my wife always chides me when driving any of our cars, when I turn on the turn signal earlier than needed. It's an old habit, hard to break, from when I had a car with an intermittent signal and I wanted enough time to use a hand signal. Easier than fixing the problem for a lazy guy. She says the same thing each time. " You know, the flashers are built with a fixed number of clicks in the factory....when you've used them up you need a new one". Darned if she wasn't right a couple of times over many years.
Perhaps the electronic one doesn't really need to click. Maybe some smart engineer added it because they knew it would upset traditionalists if it were clickless.
vette
vette
Re: A Quite SU Pump
You might have something there Roscoe. The pump works but the ticker quit.
F Quiet fuel pump for Healey BT7 Austin Healey 5
Coyote1 General Tech Is there a quiet electric fuel pump Triumph 11
Jayplum TR2/3/3A Quiet Triumph 12
RAC68 Quiet Leaf Springs Austin Healey 4
N TR6 TR6 Spotted in the New Horror Film "The Quiet Ones" Triumph 3
RickB Since things are so quiet... my new car! Spridgets 21
Michael Oritt Quiet around here Racing 4
zimmy aweful quiet today.... Spridgets 2
Trevor Jessie Might be a little quiet here for a few days Spridgets 24
Brosky Way too quiet in Puerto Rico Triumph 19
Branson Ive been quiet.... Spridgets 62
B A Quiet 1500 Trans !?!?! Spridgets 8
jlaird Very quiet day here. Spridgets 11
delisaj Looking for a quiet muffler Triumph 28
R TR2/3/3A Fuel pump? Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
