TR4/4A AC Fuel Pump Priming Lever Stuck
bammons
I have another thread going here but I ran into a problem with the AC original fuel pump. On the advice of some I decided to replace the Moss replacement fuel pump with the original AC unit. I took the copy off. Cleaned the AC up and in the process of rebuilding it I noticed the priming lever would not move the cam lever or vice versa. Using some effort I could get it to move but I have to apply pressure to get it to go through it's movement range. So I squirted some brake cleaner in there and worked it and then some 3 in 1 oil without much effect. I have the cam lever out and the spring return on the priming lever out so neither of them is causing it. Anybody had this problem and if so how did you correct it? Bruce
poolboy
I think they are independent..I know they are on a pump for the TR6's
B
bammons
Even if they are independent, I can't smoothly operate the priming lever. It seems to hang up about mid way thru it's stroke. The replacement pump operates the priming lever when moved and vice versa. Both are supposed to operate the diaphram. Bruce
charleyf
I just went and tested an AC pump. What I got is----
The priming lever does NOT activate the cam lever.
The cam lever does NOT activate the priming lever.
The priming lever only goes what I believe is about 1/2 a stroke.
The cam lever is only moving about 1/4-3/8".
What I do get when I operate either lever is a sucking sound. Which I believe is good.
I suspect this is an older pump not recently rebuilt.
Charley
B
bammons
Ok my problem is the priming lever. On my non AC pump which I am wanting to replace with the original AC the lever goes to the top and the sides of the priming lever come into contact with the body and stops it. It should return downward where the priming lever hits the bottom stop. On my AC unit it tries to stop about 1/2 way on it's travel and can be pushed the rest of the way down with effort. I have soaked it and worked it repeatedly and it is a little less hard to push but not enough for the spring to overcome and push it all the way down. I could use it as is I guess and just not have a working prime lever. Or order a another new one to try. Bruce
charleyf
Have you removed the diaphragm and looked inside to see if the AC unit acts the same without the diaphragm?
Charley
B
bammons
Charley - Yes it is completely apart even the cam lever is out. I don't understand what the issue is but It is inside and not accessible so I think I have to call uncle on this. So I will simply buy another pump and hope it is OK. Then I will have one new one, one that is one year old and one original AC that does not function properly. You know I have been on another thread about my issues and I am just bummed out as I don't even know if it is the fuel pump or whatever else it might be. I don't seem to have much option to get a professional to look at it but I may just park it for a while until I figure something out (it cannot be driven far now). Working on the car is fun to a point then it is not. I do appreciate your help and everybody else's. Bruce
charleyf
Bruce,
With the other new fuel pump, if you push on the cam arm do you get any sounds like it is working ? If so I would then check the very fine filter located above the sediment bowl. If that is clean then I think you would be okay to use that pump.
But now you need to move to the fuel line and make sure it is not obstructed or partially obstructed. I believe I suggested how to do that in the other thread.
Charley
B
bammons
The new (1 yr) pump has a plastic rimmed filter on the bowl. Upon removing it I found it was curled up and will not straighten out. I saw that a filter can be bought that works at TSC. That was not obstructing the gas flow though that I could tell. I did release the clamp in the engine compartment (below the pump) and got a strong flow of gas so I am not pursuing that any further back. I did put together the original AC pump and am mounting it today, whether the priming lever will work or not I will have to see. This is the only fuel related thing for me to try other that rebuild the carbs. Even though my distributor was rebuilt by Advanced Dist last year I am going to change out the points and condenser. I will take a test drive and after that I don't know. I will find some shop I supposed and leave it there and hope they know what they are doing. Bruce
poolboy
Yeah, the plastic filter screen should be replaced before it starts looking like this or worse.
If there is a good fuel filter upstream, you don't really need this one, but you can replace it with the original brass screen
charleyf
Bruce, Glad that you got a good flow from the fuel line. I agree that it should mostly alleviate concern about the tank and line.
Hoping your next test proves successful. Do not give up. Keep us informed.
Do you have a fuel filter prior to the carbs? If not a clear plastic one is a good idea. It let's you see the fuel. But be aware the filters I use never totally fill with fuel. Fuel only runs in the bottom 1/3.
Charley
mctriumph
Strain ahead of the pump. filter ahead of the carbs. It is a rule to be devoutly adhered to.
Unless you like trouble.....
Mad dog
poolboy
Because of the 2 one way valves in the TR6 fuel pump, it's a good idea to filter out the "fines" before they reach the fuel pump.
B
bammons
My filter on the glass bowl on the Moss pump looks like yours Poolboy only worse. I was by a Tractor Supply and bought one of their filter screens for tractor AC pumps . However my rebuilt AC pump does not pump so back to the Moss unit for now. Ordered a new one from BPNW. I was able to talk to a mechanic I know who is in transition of moving and was unavailable to me for a while and he is coming by to see if he can help. Yes I gave up, everything I have done has had no effect or made it worse. I will post what he finds. Thanks for everybody's advice, I have often relied on what you guys say with good results but this one has eluded us. Bruce
charleyf
Bruce,
We all love a good mystery. Please keep us informed when you find the solution.
Charley
F TR6 TR6 Fuel Pump Priming Triumph 11
ronzet Priming a fuel pump???? MG 27
AndreL TR6 Conversion to electric fuel pump Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
