Priming a fuel pump????
ronzet
LBC fans, Good Morning....
Just a quick query... My '57 A now fires off and is ready for a steady stream of fuel rather than a few drops in the SUs...
Problem -- fuel feed. I rebuilt the pump. It <u>appears </u>to work -- clicks nicely but no fuel is drawn from the tank. Lines are clear... Sooo..
The query, Is there a need and a process to 'prime' the pump and or fuel lines??? OR should I just bite the bullet and buy a new pump??? or put more fuel in the tank?? OR ad infinitum...
I am all ears.. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
I have a pump on my Moss wishlist and ready to order.. Unless??? /bcforum/images/%%GRAEMLIN_URL%%/rolleyes.gif
David_DuBois
Ron - See my article Fuel Delivery Troubleshooting Guide in the Carburetor & Fuel section of the Library on this site. A SU fuel pump doesn't ordinarily need priming to get started pulling fuel out of the tank (provided there is enough ful in the tank to cover the pickup tube). I assume that you have the original type pump, a high pressure L type. If so, you may have somve severly grooved valve disks that are not sealing properly, particularly when dry. Sometimes pressurizing the fuel tank slightly will be enough to get fuel into the pump, making a better seal around the grooved valve disks. The other problem you may be having is an air leak on the inlet side of he pump. This is caused by any of the fittings being loose enough to all ow air to be drawn into the line.
Cheers,
ronzet
ronzet
David,
Thanks for the advice... Now, although I have tried, where on this site can I find your article???
Gearhead
Electric pumps don't really need "priming" does the tank have enough gas? lines clear? leaks any where else ? how does one rebuild a electric pump?
David_DuBois
Ron - Oops, wrong forum. Here is the link: https://www.mgexperience.net/article/fuel-tsg.html
Sorry 'bout that
Gearhead - As I stated in my previous post, priming is not normally needed if the check valves are sealing properly. That said, it is not uncommon in the pumps used in the MGAs for the valve disks to become severley grooved, in which case it is necessary to get some fluid on the valve disks to develop enough vacuum to pull the fuel out of the tank. In fact, when I restore these type of pumps, I squirt a little machine oil on the valve disks and seats to insure that I can get a good vacuum reading on them when doing my tests. To see what I do to restore a SU fuel pump, see my write up at: https://www.custompistols.com/cars/dave/ddsu_fuel_pump_services.htm
Cheers,
Billm
A very low-tech way to prime the pump is to turn the ignition "on", remove the gas cap and blow into it with as much of a seal as you can, for as long as you can. You may get some funny looks from those around you but this has worked for many of who couldn't afford a new pump when we were younger!! /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Bill
ronzet
ronzet
Gearhead,
Yep, yep, and yep... checked all that...
rebuilding an electric fuel pump??? replace contacts, springs, diaphram, etc... lots of little parts but fun to do on a CLEAN workbench... /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
BY the way.. I gave up and bought a new pump from Moss... comes tomorrow... Wish me luck guys.. /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
ronzet
ronzet
Billm...
Tried your technique this evening... Doctor sez I can go home on Sunday....No major lasting damage /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
Platinum
Umm... it DOES work. As long as ya DON'T INHALE. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
Rob_Edwards
Bill
Easier to stick a piece of hose into the filler, seal the hose & filler with your hand, then blow on the hose. Also a good way to start a siphon -- while keeping the hose & filler sealed, stop blowing & quickly direct the hose into your gas can. The pressure in the tank forces the gas back up the hose and starts the siphon....
HTH!
Platinum
"Tune in NEXT week kids! We'll teach ya to pick a five pin LOCK!" /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
ronzet
ronzet
OH?!?!? I was supposed to BLOW into the tank...no wonder it didn't work... /bcforum/images/%%GRAEMLIN_URL%%/crazy.gif
Smoking??? It is amazing how loud a gas explosion is and how bad hair smells after it is singed. I needed a haircut anyway... /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
You can send me flowers at the DumbA#$ Community hospital... /bcforum/images/%%GRAEMLIN_URL%%/square.gif
Nunyas
it worked for me... I rebuilt my SU fuel pump not too long ago, and I ended up huffing and puffing into the tank until it built up enough pressure to force the fuel into the pump.
ronzet
ronzet
Nunyas,
Thanks to you and everyone else for the suggestions... With a new pump that I will install tonight I will huff and puff my way to success... /bcforum/images/%%GRAEMLIN_URL%%/banana.gif
Platinum
With a NEW pump the huff 'n puff is excess to requirement!
...where's th' challenge in THAT?!?! /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
We didn't spend YEARS dedicated to finding all these elegant work-arounds just so YOU could go off 'n buy a brand-new pump and negate all that effort, research and toil!
*sheesh*
ingrate. /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
ronzet
ronzet
DrEntropy,
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]We didn't spend YEARS dedicated to finding all these elegant work-arounds just so YOU could go off 'n buy a brand-new pump and negate all that effort, research and toil!
[/QUOTE]
Now I feel like a real putz... /bcforum/images/%%GRAEMLIN_URL%%/square.gif
I will hang my head in shame as I realize how ungrateful I appear... /bcforum/images/%%GRAEMLIN_URL%%/cryin.gif
I have had trouble answering your post... I was laughing so hard that I couldn't type... /bcforum/images/%%GRAEMLIN_URL%%/lol.gif
Thanks guys... /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
ronzet
ronzet
David,
With what I have seen of your expertise in LBCs and the quality of the articles that you have posted... /bcforum/images/%%GRAEMLIN_URL%%/bow.gif
We should petition to have you promoted to a full <u>YODA</u> status before you hit the posting number!!!/bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
Thanks for your help... /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
ronzet
ronzet
Rob_Edwards,
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]...to stick a piece of hose into the filler, seal the hose & filler with your hand, then blow on the hose. [/QUOTE]
This is deffinately easier to visualize than blowing into the gas tank fill pipe directly...
My neighbors already think I am /bcforum/images/%%GRAEMLIN_URL%%/crazy.gif and going to my knees and blowing into the tank would absolutely bring a cease and desist order to my door... /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Decorum, gentlemen, decorum, please... /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
Nunyas
heh...
I remembered that when I rebuilt my pump, it ticked away happily until I primed it with my lungs. After which, it only ticked enough to build up pressure. A few days later, I found that I hadn't rebuilt it to the spec I should have. The points weren't ticking over as effectively as they should have, and took me a couple of more days of tweaking the points assembly to make them trip as effectively as they should.
Now, (a month later) it still only ticks enough to build up pressure after sitting for a couple of hours, but I no longer have to worry about it completely stop pumping fuel while I'm on the road. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
F TR6 TR6 Fuel Pump Priming Triumph 11
tweety Fuel priming question Spridgets 15
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
Walter74 Oil Priming the Engine Austin Healey 8
Jim_Gruber Priming oil pump Spridgets 9
tinman58 TR5/TR250 OIL PUMP Priming Triumph 3
A TR2/3/3A Tr3A Oil Priming Triumph 11
TulsaFred Oil pump priming access Spridgets 8
S TR6 priming TR6 oil pump?! Triumph 18
1 Question about priming chassis? Austin Healey 6
G Priming the Oil Pump Triumph 5
ronzet MGA Priming the OIl Pump... MGA 1500 MG 15
B YAY!! IS BODYWORK PRIMING TIME!! Spridgets 6
S TR2/3/3A tr3 priming the oil pump Triumph 2
E Rust removal and priming Triumph 3
S Oil Pump Priming Austin Healey 4
W What is the proper procedure for priming S.U.175's Triumph 4
R TR2/3/3A Fuel pump? Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
