Well I Tried with a new SU fuel pump
Coalhod
Hello;
I purchased a new points style AUF214 about 4 months ago to replace what looked like the original one from 1965. Had all the brackets, fit perfectly as per factory. I only drive the car occasionally anymore, especially during winter months here in the East as the snow/salt tears up the sheetmetal.
Anyway took it out for a drive yesterday and sure enough fuel starvation set in so I pulled off the road and a couple of raps on the fuel pump got it going enough to make it home. Probably less than 200 miles driven with the new SU pump. In all fairness, Burlen warned me that the solid state version would be better suited for a vehicle that is not used much. What I do like about the points set up is I can get it running again whereas solid state would need a tow.
I had a backup pump that I installed today, a Facet "Posi-Flo" pump that does not make as much noise as a Facet cube type pump I had prior to the SU and it made a lot of racket although it never let me down even though it is solid state.
So, will clean the points on the SU and possibly sell although the plus to me on this pump is it fits as it should on the car. May even consider running both and set up a switching system should one of them stop working.
Andrew
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
M Wanted I tried to post this earlier and it didn't seem to work so this might soon appear as Austin Healey Classifieds 6
Got_All_4 TR2/3/3A Has anyone tried this new steering box top plate Triumph 14
S Anybody tried this Alternator ? Austin Healey 11
Simmo MGB Have you ever tried removing the spring clip on the Keylock from inside the door MG 0
jdubois Anybody tried these floats? Triumph 7
W Tried to start the Whitephrog for the first time Spridgets 5
S I've tried just about everything but....... Triumph 7
W Anybody tried this before... Spridgets 11
M Side Curtain Rubber Has anyone tried MacGregor? Spridgets 2
R mech. water temp gauge repair? have you tried this Spridgets 4
RickB Cleaning of plastic windows - just tried McGuire's Spridgets 5
angelfj1 Liquid Powder Coating - has anyone tried this? Restoration & Tools 4
B Trimcar upholstery. Anyone tried these guys? Triumph 4
MGBGT_noob MGB Has anyone ever tried this with an MGB? MG 10
M T-Series Has any TD owner tried radial tires? MG 20
mgblue79 Has anyone tried E85? Spridgets 16
W Home-made tonneau - has anyone tried? Triumph 15
B Has anyone tried this with their Healey? Austin Healey 9
B Tried a New Shop for the Audi Other Cars 2
S Tried a new Elise on for size Lotus 29
S Anybody tried Eastwood's Tin Zinc Electroplating? MG 4
J Has anyone tried The Amazing Roll Up Car Cover? Restoration & Tools 18
R TR2/3/3A Fuel pump? Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
