XJ12 Fuel pump relay 85
Pablo 1
Hi all.
My name is Pablo and I am from Spain and this is my first thread.
I own a XJ12 form 1987 and I got a problem with it.
The main issue is that once it is started the engine shuts off. I noticed that when it shuts off the 85 on the fuel pump relay loses ground. It doesn’t lose the 30 or the 86, it just loses the 85.
I checked the wire from the relay to the ECU at the trunk, the wire is in good condition, I anyway did a jump wire isolating the original one but the same thing happens. I read the entire manual but i can’t find any explanation why the ECU stops grounding the relay. I used the oscilloscope checking the 85 of the relay and the injector signal and fist the 85 ground dissapears and after a couple of seconds the engine stops and loses obviously signal to the injectors, so it is clear that only the relay pump loses activation. The next thing I am going to do is to check what happens with the 50 signla to the ECU and the positive and negative of the ECU but to be honest I thing that I am not going to find anything.
Have you ever have guys this problem before? Could the ECU be the problem?
Thank you and sorry for my english.
Platinum
Welcome to the forum, and your english is great, your explanation outlines the issue perfectly.
The pump relay should energize at the first turn of the ignition to the "run" position for a few seconds to build the pressure in the rail, then continue as the starter is engaged. When the key is released from the starter position, the ECU is ~supposed~ to understand it should continue to provide voltage to the relay. Sounds as if the ECU is faulty, but there are other possible problems also: ECU ground, ignition switch with possible bad contact (as stated before: the pump should run a few seconds on first engaging the 'run' position), bad crank sensor... I'm sure there are others.
Haven't seen an XJ12 in a long time, so can't think of much else. Hope someone can jump in here with further suggestion.
P
Pablo 1
Hi, hopefully this weekend I will be able to get my hands on the car, I have read about problems with 6CU ECUs and the fuel pump relay activation, so the only thing I am gonna check are the positive and grounds of the ECU and if that is in order (wich I assume it will be) I will open the ECU and see what happens.
I will keep you posted.
P
Pablo 1
Hi, sorry for the long wait, I wasn't able to work in the car until some days ago. Finally I resoldered the ECU but the problem was still there. I finally solved the problem installing a fuel pump relay from Opel, serial number is 1238563, here we call these relays taquimetric relays it gets signals from coil, starter, etc it basically does the same function the ecu does internally. It is running perfect now.
Thank you!
Platinum
Good news! And an interesting "work-around"! (y)
T Question on 1994 XJ12 fuel pump Jaguar 3
P XJ12 Wiring diagrams Jaguar 1
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
L 94 XJ12 Jaguar 1
D How much room in the XJ12[ 3] /XJ-S engine bays? Jaguar 0
Basil Check out V12_Jagman's XJ12! Jaguar 2
L XJ12 Horns Jaguar 2
E XJ12 Purchase advice Jaguar 4
B A Few Questions about my XJ12 Jaguar 3
R TR2/3/3A Fuel pump? Triumph 11
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
